Old 7th May 2017, 11:32 PM
nath nath is offline
Default rear brakes
just a little bit of info gents
changed the rear discs and pads on my a8 the other day and had a little shock
i was able to change the discs and pads WITHOUT REMOVING THE CALIPERS
this is the first car i have ever known this to be possible
a very pleasant surprise as it looks like the bolts which hold the calipers on are difficult to remove (m14 spline or triple square)
the discs were 356mm rears
hope the info helps others
Old 12th May 2017, 01:09 PM
A8 Ian A8 Ian is offline
What year and engine is your A8 ... I think this is possible on a 3.0tdi but not the larger ones .. but I could be wrong
Old 24th May 2017, 12:21 AM
its a 2010 with 4.2 tdi engine
front disks are 385mm rears are 356mm
