Old 16th April 2017, 04:11 AM
roberto's Avatar
roberto roberto is offline
Default A8 D3 detachable Towbar Wanted..Westfalia prefered..Info on fitting please too..
as above for my mates D3
he has Towbar mode on the MMI
but nothing else
does anybody know whats involved in fitting/wiring etc to factory spec
thanks
Old 16th April 2017, 07:22 AM
Take a look at these PDFs, should tell you all you need to know
http://www.pfjones.co.uk/westfalia_fitting/305276.pdf
http://www.pfjones.co.uk/westfalia_f...5227300113.pdf
Old 16th April 2017, 07:32 AM
Johnmed's Avatar
Johnmed Johnmed is offline
I fitted mine and the brother in law helped with generic wiring install. Covered in a thread on here somewhere. If you use the OEM wiring and module it's much easier, but more costly.
I have to manually select towing mode, cos it's generic wiring. I think, not sure, that VCDS is required to code in the towbar with OEM wiring.
Essentially you need to remove most of the boot floor's carpet or lift it up, the rear bumper and drop the rear silencers a few inches. I backed my car up ramps and it was relatively simple. I didnt have large splined bits, which you need in addition to torx, machine mart saved the day.
Essentially you remove bumper, and impact bar and slide the U shaped towbar under the boot. I bought new fixings from Westfalia (who were really obliging), as my towbar was used.
2007 Mini Cooper S R56
Old 16th April 2017, 07:48 AM
clubadria clubadria is offline
Hi I bought mine new from Westfalia with the 13 pin socket and extra wiring kit for caravan as they don't come standard.
Fitting bar as said fairly easy wiring all fitting behind battery had to come out makes it easier. only when I put mine back that I realised that extra wires were missing.
It will need coding mine isn't and it just bleeps when reversing with caravan, everything all works just doesn't switch sensors off.
I don't have VCDS.
Don't forget bumper cut out, 13 pin folds away so nothing seen.
Would recommend they get the 13 pin genuine kit from P F Jones, I've towed for many years and always had 13pin much better than 7 pin, even if only towing trailer or for bikes.
David
Old 16th April 2017, 07:50 AM
Johnmed's Avatar
I don't have VCDS.
David
I forgot all about chopping the bumper!
Old 16th April 2017, 08:11 AM
Johnmed's Avatar
Here's the thread I mentioned:
http://forum.a8parts.co.uk/showthread.php?t=11057
There are cut outs on the bumper too, all quite simple and logical, if not time consuming.
Old 16th April 2017, 09:08 AM
roberto's Avatar
great info thanks guys
