Hi.
I have a ticking noice at ca 1800-2000 rpm, the noice is coming when i run on flat ground and have almost no throttle. Also downhill with zero throttle, braking on the gears. Under acceleration,slow and fast i cant hear anything. Took an comression test all ok, and took of the valve cover, and on the bank 1 syl 1-4 the chain tensioner had a worn groove from the chain and oil around it,outside cover. Can that be a broken tensioner causing the ticking sound? Cant hear anything with a stethoscope on the engine. Hav no fault code on VCDS. Just changed oil, no difference. Its the AQH engine. Or does anybody have another solution on my problem? ![]() |
