Hi Guys, I am trying to install a old WestFalia 4E0907383A into my 2003. It doesn't appear to have a plug in loom for the control unit. I need to break in the loom to connect the 9 wires. Has anyone done this before or can advise? Regards Steve
2003, A8 D3 4.0 TDI |
I haven't done a D3 before, but I have installed towbars on a number of cars.
The most relevant is the D2. The official wiring kit for the D2 is obsolete, and can't be found. I'm not sure how advanced it was in relation to the ECU/ESP, but I expect it would disable the parking sensors, which mine currently doesn't and is a pain whenever I reverse a trailer! If you can get a factory loom for a D3, I suggest you do, as manufacturers quite often do a lot of work on towing kits to tie them in to things like the stability program and parking sensors. If you can't find one, you will need a relay box - these are small and inexpensive and can be had from towbar installers and caravan places. They are needed to keep the trailers' electrical drain off the lighting circuits (thanks to bulb warning). You will need to find a suitable ignition switched live circuit and tap into it (dual fuse taps are good for this). You will need to tap into the lighting circuits at the rear of the car. The D2 has a great feature here in that the lights themselves have spade terminals for each of their circuits making tapping the lights extremely simple! I'm not sure what you use your extra pins on your trailer plugs for (we only have 5 or 7 pins on our plugs), but you will then need to tap into any additional circuits as required and couple to the relay box.
Cheers Marty ____________________ Current: 2001 Audi S8 - Brilliant Black with Black interior, C5 RS6 rims (whenever I actually put them on...), Solar Sunroof, Tinted side and rear glass, RNS-D, Grom, Bose, clunky old phone in arm rest! 2002 Audi S8 - Project Replacement head coming arrived ![]() Silver with Black interior. All features as the '01, with the 'S' mode auto shifter. Dodgey rear tint (need to find a way to get rid of that). Family: 2009 Volvo XC90 V8 R Design - has a louder more obnoxious exhaust than the S8, sounds great! Love this thing - Q7 was double the price, and certainly not double the car! Sold: 1997 Audi A4 - Hamilton's Club Sport, Achat Grey (will miss the old girl) |
I don't think and D3 came pre-wired. The factory bar is Westfalia as is the ECU, they do a retrofit loom and ECU kit which is identical in function which you can see here.
You can download the instructions as a PDF to see what is involved ![]() |
Have you read this thread on audiworld? Maybe it could be of any assistance.
https://www.audiworld.com/forums/a8-...t-1-a-2848793/ |
Thanks Guys, Ive used a add on smart box in the meantime until I get time to sort.
UPDATE: I've successfully installed the orginal trailer controller into the my D3. Benefits include: automaticity switches to towing mode (when plug is attached), in dash trailer turning signal.
Using a7pin, plan to upgrade to 13 pin in future. ![]()
