Old 14th January 2018, 10:33 PM
ChiefUno ChiefUno is offline
Default help wanted with power drain
Hi guys
A while back when I got my S8 I took it to be washed. After this I saw that I had water in the trunk, where the radio, nav and soundsystem is located.
I had a new(used) radio installed as this failed.
Ever since this I´ve had power drain.
I´ve had a new battery fitted both by audi and again 6 months later, by another shop as I didnt know why the power got drained.
I found out its because the car never goes to sleep, when I lock the car.
The only way to make it sleep, is if I pull one of the fuses for either the Nav unit, the radio or the soundsystem.
I had the local Audi dealer do a test and they suspect the control head ( Interface box) to be faulty. However they wouldnt guarantee it. If they were to fix this it would set me back around £1300. I´d rather not do this as they wouldnt guarantee anything.
What I find odd, is that they started fault finding behind the glove compartment where the interface box is located, and not where my issue started.
I´ve tried to disconnect the Nav unit and put in a loop on the MOST and when this is in place, the car goes to sleep.
That made me think that maybe it was the nav unit, that was the culprit, however, after replacing this unit, the car still wont go to sleep.
I have bought a second hand interface box, but havent gotten around to installing it yet.
What would you guys suggest that I do, to get rid of this error?
Old 15th January 2018, 09:55 PM
neeldub neeldub is offline
Have you had a full VCDS scan performed and do you have the KESSY keyless system?
Previously:
2010 Audi A8 4E Quattro Sport TDI Oyster Grey
Currently:
2015 Audi A8 4H Sport Executive Quattro in Monsoon Grey
Old 16th January 2018, 07:18 AM
Yes I have and I also have keyless system.
There is no error on my interface box however I do have an error on my can gateway and on one of my doorhandles.
I just can't seem to understand why if I put the most loop in place, that it then shuts down as it should
Old 16th January 2018, 09:56 PM
What have we got on the m.o.s.t
Nav
Amplifier?
Telephone ?
Dab ?
Radio ?
Television ?
What’s the fault code for the gateway ?
If you put a meter inline with the battery how many amps is it pulling out when locked up after say 25mins
Old 16th January 2018, 09:59 PM
Nav
Radio
Amp
Phone
00470 - Company Comfort Databus in Single Wire
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 95
Reset counter: 71
Mileage: 200805 km
Time Indication: 0
Date: 2017.11.22
Time: 12:12:16
I havent tested with meter in line
Old 17th January 2018, 12:28 AM
What's the error code from your door handle.. I have a strong hunch that it could be the culprit as i was experiencing power drain everyday as the locking button on the driver door handle was faulty. Once i replaced that, then the power drain vanished.
I had the following code on my car:
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Control Module Part Number: 4E1 910 802 B HW: 4E2 959 802 F
Component and/or Version: Türsteuer.FS BRM005 0180
Software Coding: 0028462
Work Shop Code: WSC 02313 785 00200
VCID: 20486A13F3B91346AA-8074
1 Fault Found:
02124 - Exterior Door Handle Switch
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 0
Reset counter: 101
Mileage: 148464 km
Time Indication: 0
Date: 2017.10.16
Time: 19:55:36
Previously:
Currently:
Old 17th January 2018, 12:29 AM
Originally Posted by ChiefUno View Post
Nav
Radio
Amp
Phone
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 95
Reset counter: 71
Mileage: 200805 km
Time Indication: 0
Date: 2017.11.22
Time: 12:12:16
I wouldn't worry about this error code as I have the same from time to time and it doesn't seem to do anything to the operation of any of the systems.
Previously:
Currently:
Old 17th January 2018, 08:30 AM
Yeah I was thinking the same about the door handles.
It just confuses me why it will enter sleep mode when I put in the MOST loop instead of the nav unit.
Old 17th January 2018, 09:51 AM
If you loop out radio or amp or telephone does it go to sleep then ?
Is it only looping out the nav that makes it go to sleep .?
The door handles like said can cause an issue but I just cannot see how looping out the nav could be linked ( but you never know ! )
By using a meter in line and looking at dormant current draw it gives you a clue as to what to look for ....is it a big draw or not so much
On the bigger cars I use a shunt inbeteeen the battery cable and ‘ tap up ‘ off that ....it’s because when they wake up they can draw a lot of current and in an average multimeter the fuse will be blowing all the time .
With the door handle buttons it’s the case that water gets in the switch and this wakes body module whilst asleep ...pulls out about 6/7 amps for a few mins at a time .
If you leave the optical cable in the nav unit but unplug the power feeds plug what happens then , does it go to sleep then
Old 17th January 2018, 01:04 PM
Hi guys
Ok I did a little more digging into this.
Here´s what I tried/found.
I went for a drive as my battery was @10% power this morning.
When I parked I put in the MOST loop in order to see how much time passed before the car went to sleep after locking it. approx. 40 seconds.
I then tried the same with the radio and amp. Same result. approx 40 sec.
I then tried leaving it all as normal, without the loop and again 40 sec.
Then I tried starting the car. Then shut it off and it never went to sleep. So now I´m at a complete loss as how to fix this.
Normally when I park my car, I pull one of the fuses for either the Radio, Amp or Nav and this makes the car sleep after the said 40 sec.
Thats the reason I was thinking it would have to be here the problem was.
As said in the beginning of this post I had water ingress in the trunk where these units are located. The only thing that hasnt been touched as of yet, is the amp. Should I find a new unit to test this or would that be a waste of money?
When I got home, I did a complete VCDS scan and this is the result.
Wednesday,17,January,2018,14:58:20:14903
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.8.1.0 (x64)
Data version: 20171130 DS276.6
www.Ross-Tech.com
VIN: WAUZZZ4E87N024452 License Plate: DZG880
Mileage: 203160km-126237mi Repair Order:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 11 31 15 16 17 19 1E 25 34 36 37 38
42 46 47 4F 52 53 55 56 61 62 67 72 76 77
VIN: WAUZZZ4E87N024452 Mileage: 203160km-126237miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
11-Engine II -- Status: OK 0000
31-Engine other -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Sporadic communication error 1000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
67-Voice Control -- Status: Sporadic communication error 1000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 4E0 910 552 HW: 4E0 907 552
Component: 5.2L V10/4V FSI ª0060
Revision: 5AH15--- Serial number: AUX3Z0G5325272
Coding: 01060003190F0160
Shop #: WSC 02313 785 00200
VCID: 5FCDFFD18E07ABBEC8-800A
No fault code found.
Readiness: 0000 0001
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E2 910 156 C HW: 09E 927 156 B
Component: AG6 09E 5,2 FSI RdW 0020
Revision: --H01--- Serial number: 0107682
Coding: 0000001
Shop #: WSC 02313 758 00200
VCID: 2447B03DE7E1C866D5-8070
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 D HW: 4E0 614 517 AB
Component: ESP 5.7 allrad H49 0500
Coding: 0001627
Shop #: WSC 27227 000 00000
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 K
Component: FBS AUDID3 H10 0190
Revision: 01904910 Serial number: AUX3Z0G5325272
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: 58BFD4CDEB295C8689-800C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
3 Faults Found:
00191 - Passenger's Door Handle Touch Sensor (G416)
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 3
Fault Frequency: 7
Reset counter: 150
Mileage: 203136 km
Time Indication: 0
Date: 2018.01.15
Time: 16:55:14
00180 - Access/Start Authorization Antenna; Passenger Side (R135)
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 149
Mileage: 203136 km
Time Indication: 0
Date: 2018.01.17
Time: 13:44:26
00193 - Rear Right Door Handle Touch Sensor (G418)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 3
Fault Frequency: 2
Reset counter: 190
Mileage: 203136 km
Time Indication: 0
Date: 2018.01.17
Time: 14:05:42
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4063338
Shop #: WSC 73430 210 01865
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 769 P HW: 4E0 035 729
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 343FK077600723
Coding: 0010002
Shop #: WSC 00000 000 08192
VCID: 397971497063A58E96-806C
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH01 0050
Subsystem 2 - Serial number: 00000000040893
Subsystem 3 - Serial number: 0120.06.070000000100010046ÿ
Subsystem 4 - Serial number: 010046ÿ
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 G
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000123359
Coding: 0041089
VCID: 1C3788DDDF91F0A66D-8048
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 Q HW: 4E0 907 279 Q
Component: ILM Fahrer H15 0230
Coding: 0133122
VCID: 36637A75417D4AF67B-8062
Subsystem 1 - Part No: 4E1 910 113 C
Component: Wischer WWS D3 H60 0420
Coding: 00000036
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00139548
Shop #: WSC 02313
Address 11: Engine II Labels: Redir Fail!
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 D HW: 4E0 959 655 H
Component: Airbag 9.41 H14 4210
Revision: 91H14421 Serial number: 0037P0G0DVS.
Coding: 0430707
VCID: 275DA73196D7237EF0-8072
Subsystem 1 - Serial number: 63328RB402A1F5E4T
Subsystem 2 - Serial number: 63428RB402A1F613H
Subsystem 3 - Serial number: 63528RB402A1F64FX
Subsystem 4 - Serial number: 63628RB402A1F616M
Subsystem 5 - Serial number: 63729RB4027E9A29-
Subsystem 6 - Serial number: 63829RB4027E9ABC6
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 A HW: 4E0 953 549 C
Component: J0527 0410
Revision: 00H04000 Serial number: 90055071280009
Coding: 0012141
VCID: 2643AA3591DD3A76CB-8072
Component: E0221 H02 0030
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 901 D HW: 4E0 920 901 D
Component: KOMBIINSTR. VDO H82 0530
Revision: D05 Serial number: AUDID3G6001737
Coding: 0032513
Shop #: WSC 12345 001 136936
VCID: 2149B929F8F3DD4EBE-8074
Address 19: CAN Gateway Labels:. 4E0-910-468.clb
Part No SW: 4E0 910 468 B HW: 4E0 907 468 E
Component: Gateway H11 0090
Revision: 11 Serial number: 200030752700A3
Coding: FCFEFBDC2B7104
Shop #: WSC 39586 001 104857
4 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 16
Reset counter: 150
Mileage: 203136 km
Time Indication: 0
Date: 2018.01.15
Time: 16:47:36
01304 - Radio
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 190
Mileage: 203148 km
Time Indication: 0
Date: 2018.01.17
Time: 14:02:25
01301 - Control Module for Voice Recognition (J507)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 190
Mileage: 203148 km
Time Indication: 0
Date: 2018.01.17
Time: 14:02:25
00384 - Optical Databus
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 3
Reset counter: 190
Mileage: 203148 km
Time Indication: 0
Date: 2018.01.17
Time: 14:03:28
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
Component: MP3-Changer H46 0390
Revision: 00046005 Serial number: AUZ5ZBG3422454
Shop #: WSC 00000 000 00000
VCID: 1A3B8EC5D5A58E967F-804E
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0410624
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 190
Mileage: 203136 km
Time Indication: 0
Date: 2018.01.15
Time: 16:55:14
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 149
Mileage: 203136 km
Time Indication: 0
Date: 2018.01.17
Time: 13:44:26
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 150
Mileage: 203136 km
Time Indication: 0
Date: 2018.01.17
Time: 14:05:42
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 L HW: 4E0 907 553 H
Component: LUFTFDR.-CDC H07 6340
Coding: 0015510
Shop #: WSC 27227 141 06276
VCID: 2C57581D8F3100261D-8078
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H02 0010
Coding: 4063328
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 C
Component: MNS ECE H41 1060
Revision: 00000000 Serial number: 305AF037521880
Shop #: WSC 00976 210 80405
VCID: 3B756B417A5F979E84-806E
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H05 0090
Serial number: 00000716200052
Coding: 0003206
VCID: 1D3185D9C48BF9AE9A-8048
Part No SW: 4E1 910 802 B HW: 4E1 959 801 D
Component: Türsteuer.FS BRM005 0180
Coding: 0032620
VCID: 204FBC2DF3F9D446B1-8074
1 Fault Found:
00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 0
Reset counter: 189
Mileage: 203136 km
Time Indication: 0
Date: 2018.01.15
Time: 16:49:24
Address 46: Central Conv. Labels:. 4E0-910-289.lbl
Part No SW: 4E0 910 289 D HW: 4E0 907 289 D
Component: Komfortgeraet H08 0020
Revision: 00200008 Serial number: W040706260187
Coding: 0005224
VCID: 2A5B5E0585C51E16EF-807E
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel P14H06 0070
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 R HW: 4E0 035 223 G
Component: DSP-High D3 H03 0120
Revision: PROD_01 Serial number: 00000000000948
Coding: 0000026
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 B
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000007839
Coding: 0011101
VCID: 1E3382D5C98DE2B683-804A
1 Fault Found:
02267 - Control Circuit for Relay for Washer Fluid Heater
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 150
Mileage: 203136 km
Time Indication: 0
Date: 2018.01.15
Time: 16:43:00
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 D
Component: Türsteuer.BF BRM005 0180
Coding: 0032620
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0000731
Shop #: WSC 27227 141 173470
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000018
VCID: 2959A10980C3150EE6-807C
Subsystem 1 - Part No: 4F0 941 329 D
Component: AFS-Modul links H01 0010
Subsystem 2 - Part No: 4F0 941 329 D
Component: AFS-Modul rechtsH01 0010
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 541 S
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 388EW077626170
Coding: 0000001
Shop #: WSC 31414 790 00001
VCID: 31694969A8136DCE2E-8064
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000007811
Shop #: WSC 43650 001 104857
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 351213D08A
Coding: 344530393135313035412056413033353132313344303841
5 Faults Found:
02272 - Quiescent Current Stage 1
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 203136 km
Time Indication: 0
Date: 2018.01.15
Time: 18:54:14
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 203136 km
Time Indication: 0
Date: 2018.01.15
Time: 19:00:39
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 203136 km
Time Indication: 0
Date: 2018.01.15
Time: 19:00:55
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 203136 km
Time Indication: 0
Date: 2018.01.15
Time: 19:01:05
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 203136 km
Time Indication: 0
Date: 2018.01.15
Time: 19:01:15
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 D
Component: Türsteuer.HL BRM005 0180
Coding: 0032620
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 S HW: 4E0 035 753 A
Component: SDS 3502 UK H45 0630
Revision: 00000000 Serial number: 00000704300245
Shop #: WSC 12336 024 394758
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 D
Component: Türsteuer.HR BRM005 0180
Coding: 0032620
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0040
Revision: 00H12000 Serial number: 08720717005046
Coding: 0201108
VCID: 2345B321E2EFCF5EAC-8076
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 M HW: 4E0 862 335
Component: Handyvorb2 H16 1130
Revision: 00000000 Serial number: 00000007684911
Coding: 0010900
End-------------------------(Elapsed Time: 03:35)--------------------------
I´m quite certain that the errors marked with RED is bacause I disconnected the MOST.
The errors marked in BLUE is becasue of my low battery voltage this morning.
ANY and ALL help is greatly appreciated.
thnx
