Old 17th February 2020, 07:40 PM
Default Exhaust tinkering
The D2 S8 has a donut-joint between the passenger side downpipe and cat, to allow the cat to be removed for access to the gearbox. Unfortunately most of them are looking pretty crusty by now, this one particularly so!
This is beyond salvation, and obviously unobtanium now - Prestige don't have any, and I don't have any good ones so time for a new solution.
Start with a 3D printed prototype to test fitment
That fitted the pipe quite well, so I sent the file to the local steel stockholder who CNC plasma cut me some flanges (minus small holes as the plasma won't cut them)
Drill mounting holes
Then stick it in the lathe and turn a chamfer in to one face to match the pipe
and then cut the lovely thing in half
Alas, this is the only way to get it on to the pipe.
Using the other flange, I bolted it all together to get it straight while back on the pipe. The pipe is covered in anti-spatter spray and I also used some aluminium foil between the new flange and the pipe so I didn't weld them both together.
Then attacked it with the mig, and we have this
I think this should work just fine, and I went slightly overkill and made it from 10mm plate, so it should last a few more years I need to do the same again to the cat which has the other side of this tomorrow, and then hopefully it will all bolt back together nicely
ID:	22880   Click image for larger version
ID:	22881   Click image for larger version
ID:	22882   Click image for larger version
ID:	22883   Click image for larger version
ID:	22884   Click image for larger version
ID:	22885   Click image for larger version
ID:	22886   Click image for larger version
ID:	22887   Click image for larger version
Old 17th February 2020, 08:55 PM
Flipping Nora. Wouldn't the world be a better place if MJ was in charge of it?!
Honestly, I think you are about five years away from restarting complete D2 production from Devon.
If you do I'll have one
Old 18th February 2020, 06:47 AM
Sit down, Waldo Sit down, Waldo is offline
There are so many threads on here that make me think 'What have I done?'
Are you really attached to your day job MJ?
Old 18th February 2020, 04:26 PM
#D2Life I plan to drive my D2 until the dinosaur squeezings run out, and I'll take as many others along for the ride as possible
I hate it, but it pays the bills and means that D2s can still be fun. If I did them full time, it would stop being fun
Finished this off just now. The second piece was much easier having learned a few things on the first. We end up with this:
Pretty happy with that, although yes, 10mm plate was slightly overkill 8mm next time, and make the centre hole a bit larger too.
ID:	22896   Click image for larger version
ID:	22897   Click image for larger version
Old 18th February 2020, 05:32 PM
gninnam gninnam is offline
Very cool
Andy.
Current cars:
BMW i4 M-Sport
Peugeot 207 (the sons)
Gone but not forgotten
Old 18th February 2020, 07:53 PM
I plan to drive mine eventually
Old 19th February 2020, 10:17 AM
Hey you.
You should have said, think I have some more somewhere, I had them lasered, with the small holes
Old 19th February 2020, 10:30 AM
I didn't want to draw your attention to the quality of my welding
The next batch I will get done with either a better plasma or a laser, but that has to go up to Tivvy and takes a few days. These were done by Conibeare's same-day so I couldn't be picky
Old 19th February 2020, 02:16 PM
They're tough to weld and make it look pretty. Think the ones I had cut were 6 or 8 thk so didn't need the edge prep.
I've not had much luck with laser people, getting back is too much trouble, getting it done in the next week is to much trouble, unfortunately cant go stand next to the operator and give him sweets till it's done anymore.
Mirror polished Stainless next time
Old 19th February 2020, 02:50 PM
I was putting my 3D brain into action and trying to think of another way of solving that without welding.....
Could you make each flange out of a pair of interlocking U-shaped pieces that slot onto the pipe, one from each side, maybe about 4mm thick? It should all pull together nicely once the bolts are fitted, though may need some clips (or just adhesive) to hold together while fixing?
I know a simple version as in my sketch won't apply pressure all round, that would need a protrusion on the second plate which might be tricky to make.
