Old 3rd January 2021, 06:32 PM
S81 S81 is offline
Default New to vagcom
Hi all I've order a vagcom ( Ross tech) ,and would like a car manual that includes vagcom info to allow me to identify/ check and clear faults etc or alternatively 2 separate manuals , and was wonder which is best and were to get .for s8 d3
Daily driver
Previously owned
Audi 80 1986 1.8 white
Audi 80 1990 2.0 red
Audi A4 1996 1.9 tdi green
Audi A6 1.9 tdi 2000 blue
Audi tt 225 2000 silver
Audi s8 d2 2002 fe grey
Audi a8 4.0 tdi d3 2006 black
Audi a8 3.0 tdi d3 2010 black
Old 4th January 2021, 02:48 PM
homer simpson's Avatar
Best place to start is the Ross Tech Wiki pages. They also have a forum for registered users. VCDS is very user friendly and generally won't let you do anything major without prompting you.
The checking for fault codes (scan) is easy as you just click on 'Auto Scan' and it will scan every module in the car. Any faults will show in red and you can then click on them to see what the code is. If you want to just interrogate one module, you can select it manually.
http://wiki.ross-tech.com/wiki/index.php/Main_Page
Old 4th January 2021, 06:01 PM
As far as I can tell VAG Com works the same on my D4 as it did on the D3.
Like Home said, it's user friendly and you will be able to easily figure how to clear fault codes.
For making changes to settings, I use the net and dig about.
Old 4th January 2021, 06:41 PM
Spot on Nick.
My experience tallies with you.
Old 4th January 2021, 06:50 PM
S81 S81 is offline
Thanks guys ,I had thought it was more complex ,i don't intend to change settings unnecessarily just to clear and reset faults after the winter maintenance is complete,as a matter of interest I changed rear pads and discs there and refurbed Calipers ,do i need to use vcds to reset values or will hand brake auto learn it's self ,i tried handbrake when finished and it went on and off without problem or faults coming up ( went for short test drive and all good ,wheels weren't binding)
Daily driver
Previously owned
Old 4th January 2021, 07:26 PM
What did you use to open the calipers when doing the rears?
Old 4th January 2021, 07:32 PM
carmel120 carmel120 is offline
Did you measure the pad thickness to enter through vcds YouTube is your friend.
Old 4th January 2021, 08:59 PM
S81 S81 is offline
I removed the pb motors and used a t30 torx into the Calipers to retract pistons ,i didn't measure pads (vcds has come yet but should be here in next day or two ,brakes and pb working correctly )
Daily driver
Previously owned
Old 4th January 2021, 09:15 PM
Could be old age, but i don't think you need to enter pad size on a D4
Old 4th January 2021, 10:07 PM
S81 S81 is offline
It's the d3 s8 I'm working on
Daily driver
Previously owned
