Hi all,
At long last my S8 is all back together and almost all behaving properly, apart from a weird shudder in 3rd gear when warm / hot. It only happens at light throttle, going up a hill, from 1800-2200rpm. A bit of throttle will clear it, backing off won't, and it doesn't do it in S because it will be in 2nd in the same places where it would be picking 3rd in D. It does do it in tiptronic under the same conditions. It doesn't do it from cold - it needs to be driven for about half an hour, although I haven't spotted the temperature it starts at yet. >45* I think. Its quite a vigorous shudder - much more harsh than a misfire. No codes whatsoever- ecu, tcu and abs are all clear. It will throw the 11119 missing gear signal code in tiptronic, but that seems quite common. Other than the shudder it drives just fine, shifts smoothly (no thump), kicks down fine, pulls away fine. I've had a co-pilot watching vcds and there's no observable change in rpm, engine load, engine request, torque converter clutch, F125, or gear selection. The gearbox has had the problem bearing and o-ring changed (although they were fine when I took it to bits), and the clutch packs looked fine. It took the full 9 litres of fluid when I refilled it at 35*. The tcu has been encouraged to re-do its basic settings since it has been disconnected for a while. Any ideas please? I'm completely stumped and can't even find any reports of similar symptoms on t'interweb ![]() |
So everyone else is at as much of as loss to explain this as I am then I guess!
I'm just going to drive it 'til it explodes in that case, then stick an 0A3 in it ![]() |
The problem is, Mikki, that you seem pretty sharp on the mechanical end with a degree of knowledge and hands on experience that exceeds most people on this forum - so, if you dont know what the explanation is, then most others may not be able offer much.
For what it's worth, my only offering is that it appears to happen under load (uphill, light throttle in 3rd) and can be cleared by gear/throttle change and is therefore more likely to be fuel mixture issue rather than mechanical.... maybe?
My old S8 used to do it until I changed the fluid and filter.
I suspect its the valve bodies not closing or connecting properly causing it to not choose the correct gear. Do a filter change, check the levels and see how u get on. |
Engine sounds fine, and the gearbox otherwise shifts ok ?
So, how about torque convertor ? It will try and lock up around 50mph when in drive. In tiptronic, it locks up much sooner. Does the problem happen in tiptronic, and drive ?
For parts enquiries and Forum User Administration please contact customer services directly, not me ![]() The Daily Town Car - 2023 Tesla Model Y Performance. Black with Black. Giant ipad screen, huge sunroof, 4 wheel drive, Tow bar, lots of ooomph and made in China, so actually built properly unlike the Californian ones. The Family Wagon - 2018 Tesla Model X. Black, 7 Seats, Towbar, Homelink, Enhanced Auto pilot with Summon and self park, Heated front seats, CCS Charger upgrade, MCU2 Upgrade, Falconwing Doors, Self opening / closing doors, Netflix, Spotify, toys, Air suspension, alcantara roof + lots of other stuff...... The 17 year old Driver Wagon 2015 Skoda Citigo Monte Carlo. Alloys, Power steering, Aircon, Leccy windows, Sat Nav, bluetooth, central locking, cup holders, 59 whole bhp. Million times better than my first car. Well jealous..... The First 20 Audis: 2001 D2 4.2 QS Silver, 1997 D2 S8 Silver, 1999 D2 4.2 Silver, 2002 D2 S8 Dolphin Grey, 2003 C5 RS6 Blue, 1998 D2 S8 Black, 2000 D2 4.2 QS/S8 Ming Blue, 2003 D3 4.2 Ming Blue, 2005 B7 S4 Blue, 2006 D3 3.0 Tdi Black, 1999 D2 4.2 Silver, 2003 D3 4.2 LPG Crystal Blue, 2000 D2 S8 Silver, 2007 3.0 Tdi Q7 Black, 2009 B8 S4 Black, 1998 D2 S8 Agate Grey, 2006 D3 4.2 Tdi Blue, 2006 D3 S8, 2007 Q7 3.0 Tdi, 2006 C6 S6, The Second 20 Audis: 2011 A7 Sline, 2001 A2 1.4 Tdi Black, 2002 A2 1.4 Tdi Silver, 2006 A8 4.2 Tdi Blue, 2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black ![]() 2010 A8 D4 4.2 Silver, 2006 C6 A6 2.7 Tdi Quattro, 2000 D2 4.2 QS/S8 Ming Blue (again), 2008 Q7 4.2 Black, 2009 C6 RS6 Saloon Daytona Grey, 2001 Fully Loaded A2 Tdi, 2006 Avant S6 Black, 2007 VW Caravelle Exec Black (almost an Audi) 2009 TT Roadster Daytona, 2015 Q7 4.2 tdi lava grey, 2002 GmbH D2 demonstrator, 2006 D3 A8 LWB 4.2 Tdi Black Most Recent Audis: 2001 A2 1.4 Tdi Black, 2007 4.2 FSi Q7 ABT Blue, 2016 S5 Coupe Launch model, 2004 S4 B6 Cabriolet, 2016 Q7 Sline White, 2006 Q7 4.2 FSi Black, 2012 Q7 Sline+ 4.2Tdi White, 2008 Blue Audi S8 Everything Else 1989 Subaru Justy, 1986 Vauxhall Cartlton 2.0 GL, 1985 Vauxhall Carlton 2.2 CDi, 1987 Ford Sierra XR4x4, 1983 Vauxhall Senator, 1985 Vauxhall Senator 3.0i, 1997 Polo Saloon, 1997 Peugeot 306 1.9 TDi, Ford Sierra Sapphire 2000E, 1990 Subaru Justy, 2000 Subaru Impreza, 2000 Subaru Impreza RB5, 1993 Range Rover LSE, 2005 VW Bora, 2003 Skoda Superb, 2003 VW Passat V6 4 Motion, 1996 Peugeot 106, 2000 Range Rover 4.0, 2019 Tesla Model 3 Performance |
The engine is glorious
![]() I *think* happens in both tip and drive in the same conditions but actually on the last test drive I was avoiding tip since it keeps throwing the 11119 gear signal code in the ABS. I couldn't quite follow what VCDS was telling me about the TC - it was open, closed, and re-something, none of which seemed to correspond with what I thought it should be doing. I'll try it again and report back. DaveMcB - it has just had new fluid and filter ![]() David'S8 - thanks for the compliment! If it was a 4 or 6 I'd be all over it, but this is the first time I've properly worked on an 8 or a 5HP24 so I'll take all the help I can get -fuel filter soon ![]() |
Sooo... took it out for a hundred miles or so today. The shudder happens in 1, 2 and 3 in the right circumstances - low rpm, light throttle, mostly up hill but not always and also happens in D, S and Tip. At one point pulling away from a stop up a hill it did it in 1, 2 and 3 in succession until I got annoyed and booted it. Lots of throttle and it doesn't do it at all - Tip or S on the twisty bits and it is perfectly fine (and wow does it move!!!). The shudder really spoils the experience though.
I am a bit surprised how low geared it is though. I knew the S8 had different ratios to the others, but 3K at 80 seems a bit excessive for a V8. That's about the same as the TT 225 whereas my 3.7 was geared the same as a diesel. The gearing is quite an incentive for a manual conversion whether the auto goes bang or not... |
Having thought about this a bit more I've realised that the problems really started when it was low on fluid before I took it out. The gearbox sump had been fitted with bathroom sealant so it was ****ing oil everywhere. I only checked it when I pulled the drivetrain, but it was whining quite badly just before that. The oil level was down to the join between the sump and the casing so I'd guess about 3 litres short.
I'm wondering if this did some permanent harm to the TC before I even took it to bits, and so whatever I've done afterwards has actually had no effect on the underlying problem. Given our sponsor's online sale, is it worth sticking in a used TC before I tear it all apart again? At least I can drive it while I collect manual conversion parts then... |
Well I bought another TC in the sale. Barring any bright ideas to do with the valve body I'll make a start pulling it out next week.
