Old 7th November 2014, 07:32 PM
Thumbs up HOW TO: Fix Mic & Voice Control NOT Working after MMI Update
First of all my apologies for doing it so late, but originally (few months ago) I just completely forgot to do this straight after fixing this issue.
After 2 days with massive help from Del, Mannyo and PsYcHe we finally got to the bottom of this problem.
Some users with Bluetooth telephone and Voice Control have issues with following functions NOT working after MMI Update to ver. 5570:
- Microphone [telephone] (when connected via Bluetooth, caller can't hear you, but you can hear them)
- Voice Control (''Button Not In Use'' after pressing VC button on the steering wheel)
Solution is weird, but simple.
First go to [07] Control head and then CODING
Change coding to 0000002 --> Do It
Exit controller
Then go to [77] Telephone and then CODING
Change coding to 0010900 --> Do It
Exit Controller.
Exit VCDS and wait 30sec.
After 30sec REBOOT MMI by pressing ALL 3 buttons at the same time:
TEL + Selection Button + TOP RIGHT sub-menu button as per picture below
After reboot you should have everything back and working again as it should.
The trick is to tell the car if you have all this gizmos that you don't have them, weird, but this is Mannyo's explanation:
If you have voice control, then the microphone is connected to the Voice control module since it is possible to have voice control and no bluetooth.
You code the phone module without voice control because the voice control module is in effect controlling the infotainment (including the phone as it is part of the infotainment).
If you code the phone module for voice control, then the phone module will expect the microphone to be connected directly to itself, and it in turn would then handle the voice control. As a side effect, since voice control is now listening through the bluetooth module without a microphone, the whole thing stops working.
So far Me, RicharRacer and Scott had this exact same problem and in all 3 cases this solved both issues.
I hope more people will find this helpful ++
ID:	9440   Click image for larger version
ID:	9443   Click image for larger version
Old 7th November 2014, 09:17 PM
I had this after my bluetooth retrofit. Worked fine until I recoded it to have SDS thinking that was obviously correct but it just disabled SDS.
Old 7th November 2014, 09:19 PM
Added to sticky thanks chaps
Old 7th November 2014, 10:10 PM
Cheers Neil
SDS??
Old 7th November 2014, 10:14 PM
Very useful Marcin
Sds, speech dialogue system
Matt
Old 10th November 2014, 07:47 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
That solved my issue Friday night after updating my MMI to 5570.
Thanks
[center]
06 3.0TDI Quattro:
Options:
Old 10th November 2014, 08:52 AM
So do you now have everything back working with all the options in the menus Scott?
Old 10th November 2014, 09:03 AM
ScottD3's Avatar
I'm still missing the instrument cluster option but everything seems fine.
[center]
06 3.0TDI Quattro:
Options:
Old 10th November 2014, 02:56 PM
mannyo mannyo is offline
For instrument cluster see post one in my thread.
http://forum.a8parts.co.uk/showthread.php?p=67354
Manny
Past
Old 3rd June 2023, 02:58 PM
zed_thirteen's Avatar
zed_thirteen zed_thirteen is offline
Audi A8 D3 3.7 petrol, 2003
My microphone has stopped working since changing my analogue radio module (the old one failed and took out the MOST bus)
I think the microphone is working because I see variations in signal if I graph group 19 in Telephone Module (77) and then tap the roof console (I don't know where the microphone is!)
Now, my old analogue radio didn't have a voice module but some steering wheel voice commands appeared to work - but I didn't really use them.
The replacement analogue radio does have a voice module plugged in to it but group 67 is saying it has component protection. Pressing voice command button on steering wheel shows a message about "But. not used".
My coding is: Address 07 Coding 0000002 and Address 77 was 0010900 but I changed this to 0010920 but it didn't make any difference,
Is it the voice control module that is preventing my microphone from getting through? Can I just remove it from the analogue radio and set my coding back to 0010900? I don't think i want to pay Audi £100 to get component protection removed.TIA
2003 A8 D3 V8 3.7l petrol - retro fit audi handsfree bluetooth, DAB Radio, Digital TV, fully populated aerial amp, metal capped window and handbrake switches, brushed metal dash trim and switches, graphic parking sensor display
