Old 18th September 2012, 10:31 AM
Default Auto dimming rear view mirror
Has anyone retro-fitted one of these to a face-lift 2002 D2? There seems to be a heck of a lot of wires to connect and, apparently, it's not already wired for one (as I had hoped!).
Old 18th September 2012, 10:37 AM
Facelift = no prewiring anywhere, for anything
Autodim wiring from memory has power and ground in, a reverse feed in (so it lightens up when you select reverse) and then it has outputs that can drive the exterior autodim mirrors....
So, worst case power and ground would get it working - It depends how much of a perfectionist you are as to whether you run the reverse feed too
Old 18th September 2012, 10:41 AM
I've fitted one to a PF which wasn't that tricky, though I do know it's a physically different mounting for FL I can't think anything else would be much different.
There was no pre-wiring at all that seemed relevant.
I think most of the extra wiring would be for controlling dimming external mirrors and I ignored that aspect as I don't want them. Also ignored the reverse feed.
I think I only had to connect 2 wires (of how many? - honestly can't remember) basically 12V and earth. I took the 12V from one of the feeds to the sunroof which is "managed" so cuts off when the car is locked or engine is off for some time - found by testing with a meter.
Edit: The external mirror dimming is probably not "that" difficult if you want to do it, I think you just need to run 2 wires to each door (bit of trim removal and cunning routing via existing rubber ducts I guess). My mirror units are actually pre-wired for auto-dim so you just need the extra wires on the incoming loom and new (VERY expensive) mirror glass.
Final tip - I tested mine off the car first with a 12V DC supply (and masking the sensors with fingers and thumbs) to confirm which wire was which and that it worked OK.
Old 18th September 2012, 11:02 AM
That sounds not too bad. I don't have dimming external mirrors (and don't want them) and I could live without the reverse thing.
Thanks gurus!
Old 18th September 2012, 11:17 AM
I decided the reverse thing was pointless as I use the external mirrors and turning my head when reversing.
Also, if there's something close enough behind and bright enough to dim the mirror you'd be pretty aware of it!
Only thing I do find is that the sensor angle is such that it still picks up on vehicles overtaking you when no longer in your field of view, so you get dimming continuing too long.
(a problem that doesn't happen in my Focus as the mirror position and rear side window shape shields it)
Old 18th September 2012, 11:30 AM
Just for reference, from the earlier thread on the same subject: http://forum.a8parts.co.uk/showthread.php?t=1100
This is the PF wiring, is the FL mirror wiring similar?:
Originally Posted by IT :
Black with blue trace = ignition + 12v
Brown = Ground
blue with red trace = Reversing feed
Posted by me:
6 wires in the lead, including the 3 above:
Brown
Blue with red trace
Red
Yellow
Green
And:Well I've verified the 2 important wires:
Brown = Ground
And tested it works by jury-rigging the lead to a 12V DC wall-wart and covering the sensors appropriately.
