Old 2nd February 2011, 08:31 PM
Mick Mick is offline
Default RS6 Discs on Pre FL S8
I have come across a pair of RS6 front discs.
Are caliper adaptors readily available and if so where from?
Thanks
Mick
Old 3rd February 2011, 07:23 AM
They're not readily available, but I think they're the same fitment as the FL/D3 setups, so Ben/Oli may be able to help you out with what was needed.
Old 3rd February 2011, 04:24 PM
r8dream r8dream is offline
you cant use the rs6-c5 discs with s8-d2 calipers because s8 disc is 30mm and rs4/6 disc is 34mm wide. the fl s8 caliper will take a disc diameter up to 380mm and width up to 32mm though.
the caliper brackets to use the rs4/6 calipers on the fl s8 with the brembo system are here
http://cgi.ebay.de/Bremssatteladapte...item1c19199ed2
and also available from urquattro in the post here
http://forum.a8parts.co.uk/showthrea...1170#post11170
Old 4th February 2011, 07:04 PM
Bummer. Whats my cheapest caliper option?
Old 4th February 2011, 07:48 PM
Would B5 RS4 calipers do the job?
http://cgi.ebay.co.uk/Audi-RS4-2-7-A...item41520251e5
