Old 30th January 2011, 08:53 PM
roboblob roboblob is offline
Default lambda errors now :(
I ran my vagcom on the car tonight and these popped up , should I worry car seems fine with normal fuel consumption.
VCDS-Lite Version: Release 1.0
Control Module Part Number: 4D0 907 551 M
Component and/or Version: 2.8L V6/5V MOTR AT D02
Software Coding: 04153
Work Shop Code: WSC 00681
2 Faults Found:
16538 - Oxygen (Lambda) Sensor B2 S1: No Activity
P0154 - 35-10 - - - Intermittent
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
P0134 - 35-10 - - - Intermittent
Old 30th January 2011, 10:21 PM
16538/P0154/000340 - Oxygen (Lambda) Sensor B2 S1: No Activity
Possible Symptoms
Lambda Closed-Loop Control switches to Open-Loop Control
Increased Fuel Consumption
Emission Levels not OK
Spark Plugs become covered with Soot (might lead to misfire)
Rough Idle
Possible Causes
Lambda Sensor faulty (dirty)
Lambda Sensor Heating faulty
Lambda Sensor Wiring faulty
Possible Solutions
Check/Clean Lambda Sensor
Check Lambda Sensor Heating
Check Lambda Sensor Wiring
Old 30th January 2011, 10:37 PM
Clear the faults and see if they come back.
Old 31st January 2011, 07:12 AM
graynada graynada is offline
Or can you monitor lambda sensor activity with your version of VCDS?
If not you can by a simple Draper lambda sensor tester for about £10-£15, or if you are handy with a soldering iron you can build a better one for about £5. Details of a self build one are on my website under Tech Info.
Old 31st January 2011, 08:17 AM
Thanks for the info .I will reset the codes later and see if they come back .
not knowing the location of the sensors ,do you think its could be possible that the wiring could have been damaged by running over a lump of ice which i managed to find within a deep snowbank during the bad weather ?
Old 31st January 2011, 09:06 AM
The wiring, lambdas and cats could have been damaged as they're all in and around the exhaust region... Lambdas are up on top if I remember rightly so should be safer, but you never know.
Old 1st February 2011, 11:21 AM
I reset the errors and took it for a small squirt around town , a bit of *cough* fast driving ,binary accellerator driving (on full ,off full) ,pot holing ( normal road driving around here) and gentle cruising ..they didnt come back .Think i will keep an eye on these.
Old 20th February 2011, 07:23 AM
A8 Doc A8 Doc is offline
Lambda faults will take around 150 to 200 miles to come back fyi
