So - the saga continues.......
Replaced thermostat and put it all back together ![]() No leaks and when engine got to 90 degrees it more-or-less stayed there ![]() But - engine running rough and under load will not pull - no lights on the dash. Using the cable that Marcin sent me ( ![]() ![]() Codes: 17549 [P1141] - Load Calculation Cross Check: Implausible Value 17536 [P1128] - Long Term Fuel Trim Mil. Systroem too Lean [Bank 1] 17538 [P1130] - Fuel Trim; Bank 2 (Mult): System too Lean 17736 [P1328] - Cyl.4-Knock Control Limit Attained INTERMITTENT 17734 [P1326] - Cyl.2-Knock Control Limit Attained INTERMITTENT 16486 [P0102] - Mass or Volume air Flow Circuit Low Input INTERMITTENT 18010 [P1602] - Power SUpply [B+] terminal 30 Low Voltage INTERMITTENT I am wondering if I damaged something during the procedure of replacing the oil cooler pipe or replacing the thermostat??? Cheers
Andy. Current cars: BMW i4 M-Sport Peugeot 207 (the sons) Triumph Daytona 675 (2017 reg) =========================== Gone but not forgotten Ford Focus ST-2 Mk3 (the wifes) (stolen Oct 2023) 1972 T2 Bay Window Camper (Slow) Audi TT Mk1 225 - now with coil-overs and a 7inch touchscreen infotainment centre 2003 A8 Sport 4.2 (with ACC & LPG) (Feed up with all the issues so passed it on to a forum member) 2000 A8 FL QS 4.2 (with RNS-E - Nice ![]() Last edited by gninnam; 7th September 2014 at 02:12 PM. Reason: Put the wrong description for the first line... |
Check all the wiring you disturbed when replacing the cooler, make sure all the connections are good. Maybe even disconnect and reconnect to see what happens. It looks like a wiring issue rather than something physically wrong.
Fair comment - will have a dig around tomorrow after work.
Andy. Current cars: BMW i4 M-Sport Peugeot 207 (the sons) Triumph Daytona 675 (2017 reg) =========================== Gone but not forgotten Ford Focus ST-2 Mk3 (the wifes) (stolen Oct 2023) 1972 T2 Bay Window Camper (Slow) Audi TT Mk1 225 - now with coil-overs and a 7inch touchscreen infotainment centre 2003 A8 Sport 4.2 (with ACC & LPG) (Feed up with all the issues so passed it on to a forum member) 2000 A8 FL QS 4.2 (with RNS-E - Nice ![]() |
