Old 4th May 2012, 02:12 PM
Default Rosstech cable wanted
can + hex 2 cable wanted im tired of not being able to use vag come or vcds with my silly gendan cable with its problems connecting with the D3,
i cant get my vag com to work for love nor money and i seem to think its the cable, i get no response from controller
and its doing my nut in now
Old 4th May 2012, 09:42 PM
richardracer richardracer is offline
Talking Second request - Ross-tech cable wanted
Hello,
I am also keen to buy someone's Ross-tech cable if there are 2 available (after you daviesbike).
Keen to get to know my d3 s8 after 7 years of BMW diagnostics!
Anyone with a spare can you pm me.
Thanks
Richardracer.
Old 5th May 2012, 08:41 PM
Night Train's Avatar
IIRC Guy, that cable's only compatible with the D2, which might explain your problem. I acquired my genuine rosstech from someone who sold his D2 for a D3 '8'....
Other vehicles
Oh Yes....... The '98 PF S8!
Old 5th May 2012, 09:43 PM
RanjS8 RanjS8 is offline
Default Ross tech cable
The later audis use canbus for diagnostics, where as D2s used an older protocol KW1871 I think. Hence you have two versions of the ross tech cable. One cable is enabled for canbus and the other is not.
The canbus enabled cable will be fine for d3s and later audis....I used mine on my 2008 vw caddy without an issue. In fact with the older cable, I could still do diagnostics however I couldnt update the service interval on the instrument cluster. Had to use the canbus enabled cable to do this.
Both genuine cables you can order from Ross tech website...but I would go for the canbus enabled one as it is backwards compatible.
Old 6th May 2012, 07:10 PM
So what your saying then is if i get another cable that is a Can cable then it should work rather than the KW cable that i have now then, that would make sense, http://www.ebay.co.uk/itm/VAG-K-CAN-...#ht_3570wt_754
this jobby should do me nice then i will order that asap
Old 6th May 2012, 09:13 PM
Hi Guy,
Are you also bidding oN the Tehran can bus cable? Seems silly to bid against each other.
Richard
Old 10th May 2012, 07:22 AM
hi there sorry no i was not bidding but thanks for asking,im still looking at the one in the link above, its a buy it now, im waiting for the misses to sort her pay pal she had a new bank card and she has to link it again ect
Old 10th May 2012, 08:05 AM
That's VAG Commander cable for changing mileage, getting PIN for immobiliser, resetting airbags not the diagnostics cable.
Old 10th May 2012, 08:13 AM
What you want is :
http://store.ross-tech.com/shop/VCHUC.html
cheap clone:
http://www.ebay.co.uk/itm/VAG-COM-VC...ht_3376wt_1396
or VAS5054A clone :
http://www.ebay.co.uk/itm/Free-Shipp...ht_5348wt_1163
Old 10th May 2012, 08:59 AM
Godders Godders is offline
I got mine from here :
http://www.mi-uk.com/products/access...om-diagnostic/
UK supplier
2003 D3 A8 4.2 Atlas Grey -
Factory: Adaptive lights with coming home function, 19" wheels, Solar Sunroof, Bose, Nav, TV, Paddle shift sports wheel, sports suspension, sports seats, rear seats with electric lumbar adjustment, heated seats and climate all round, ski hatch, int light pack, auto dip/fold mirrors, voice command, cordless phone, wooden gear knob, towbar, power boot lid
After: LPG, AMI with HDD
Pending: DVB-T Tuner & fixing niggles
