Old 4th May 2009, 02:06 PM
A8 Owner A8 Owner is offline
Default gearbox leak
Hi Mrs A8 Owner here
Just been told by my gearbox has a leak,
Stev thought there might be due to the hot smell we get after a trip out, hence why i had it checked out. Weird thing is we have had this smell since we have owned the car, yet the transmission people who did oil and filter change on it didnt say a thing to me.
It seems at the back of the gearbox, high up theres a leak, poss seal gone. Anyone on here can confirm theres a seal there, or is there somthink else to look for?. Is it big job to do?, I.E lots more money?
Will be ringing transmission people tomorrow to ask why they didnt tell me about this, as it will mean ile havto payout again for oil.
any help greatfull.
Thanks
51 plate FL 3.7 sport 5 speed
Now fully detailed
Old 4th May 2009, 02:25 PM
The final drive seal is a common fault - It drops oil onto the (left I think from memory) cat and when the car is warm, the oil burns off creating the smell.
In fairness to the transmission place, they would have worked on the car coldish I would imagine when they changed the transmission oil, and when cold, the leak from the final drive seal is hard to see.
Its not a common ZF problem, its just that Audi put the cats right under the back of the box, so the rubber seals get heated up and chilled, heated up etc and they eventually dont seal as well.
Good news is that is should be only circa £100 to do, and it wont need your gearbox oil refilling as the final drive seal seals off the rear diff, not the gear change mechanisms, and this area of the box uses different oil, and only about 1.5 liters of it....
Old 5th May 2009, 03:05 PM
darrenjoe90's Avatar
hi just had mine done today. bought parts from audi and got a local garage to do it for 70 quid. also printed the following pages and took it with the parts to the garage.
http://www.audipages.com/Tech_Articl...placement.html
Old 12th May 2009, 09:11 AM
Mkoneman's Avatar
Mkoneman Mkoneman is offline
so the rear output seal need the same oil as the rear axle diff?
www.facebook.com/obdworks
full genuine ross-tech vcds
full genuine vag- tacho
Old 12th May 2009, 04:24 PM
Straight from the good book....
Old 12th May 2009, 06:06 PM
Not sure what mine is, but after I have driven her hard I see smoke coming from under the drivers side door! Anyone else had this?
Old 12th May 2009, 09:26 PM
Mkoneman's Avatar
cheers for clearing that up mike
Old 13th May 2009, 05:51 AM
Get under the car Singh and if there is a stain on the passengers side Cat then you will have a leaking seal.
Old 13th May 2009, 04:07 PM
I have the smoke as well if spanked, according to my pet mechanic it is NOT the gearbox but somewhere from the rear of the block.
I'm not worried, I just keep checking levels which reminds me, oops.
Bill
Old 13th May 2009, 05:02 PM
Somewhere at the rear of the block will more likely be camshaft cover seals. Well documented procedure on Audipages in the sticky.
