Old 31st July 2015, 09:04 AM
Default What is the 'death rattle'?
Like most D2 '8s, mine exhibits a loud rattle when starting on a cold morning (not often at this time of year though, even in Scotland). It only lasts for a second or two, but what causes it?
I've recently had a new cam belt and associated bits and pieces fitted, so should I be concerned, can I do anything about, or should I just learn to live with it?
Old 31st July 2015, 09:34 AM
Conquistador's Avatar
Mine has this sometimes. Camshaft adjuster seems to be the most likely cause.
But mine only seems to happen if I use the car every day and then it rattles the next morning when I start it. I'll not drive the car for a week or so, go to start it and it starts smoothly with no rattle.
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 31st July 2015, 10:52 AM
http://forum.a8parts.co.uk/showthrea...highlight=pump
Old 31st July 2015, 10:59 AM
What would I talk about if I could remember what I'd already talked about?
I still wish I got get rid of the noise though!
Old 31st July 2015, 11:17 AM
Glad to see you are back on form after your holiday, Brian.
Old 31st July 2015, 12:23 PM
Heavier oil might help unless you're already using it. 5w40.
Ester oil might help too, apparently it stays on metal components longer before draining down. electrostatic interaction with metal or something.
Old 31st July 2015, 12:33 PM
Dont worry Jim, I couldnt remember answering it earlier either!!
Old 31st July 2015, 12:48 PM
tintin tintin is online now
Life is a circle…often the same one, and we can all be goldfish at times. I'd have far less work if clients could remember what to do all the time!
Old 31st July 2015, 09:07 PM
B@fink B@fink is offline
Is there an aux air pump that runs briefly on first start to get the cats up to speed? a possible option for start up noise perhaps?
Old 1st August 2015, 07:19 AM
If you wanted to try and oil based option to see if it improves it, Fuchs Titan Pro Race S in a 5w40 is what I've used in mine for most services.
