Old 4th February 2013, 10:17 AM
wug wug is offline
Default Acc/Start Auth. 5 Faults Found
Hi there,
i have some errors on my car and i would like to share with you maybe we can find a solution.
I will copy/paste the errors from VCDS log:
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 C
Component: FBS AUDID3 H03 0140
Revision: 01403903 Serial number: AUX3Z0D0333088
Coding: 0409600
Shop #: WSC 02311 785 00200
VCID: D8B516B96B08CA9
Part No: XXXXXXXXXXX
Component: ELV XXXX
5 Faults Found:
00179 - Access/Start Authorization Antenna; Drivers Side (R134)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 4
Fault Frequency: 0
Reset counter: 105
Mileage: 166112 km
Time Indication: 0
Date: 2013.01.30
Time: 18:41:48
00180 - Access/Start Authorization Antenna; Passenger Side (R135)
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 105
Mileage: 166112 km
Time Indication: 0
Date: 2013.01.30
Time: 18:41:48
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 4
Fault Frequency: 0
Reset counter: 105
Mileage: 166112 km
Time Indication: 0
Date: 2013.01.30
Time: 18:41:48
00182 - Luggage Compartment Access/Start Authorization Antenna (R137)
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 105
Mileage: 166112 km
Time Indication: 0
Date: 2013.01.30
Time: 18:41:48
00183 - Interior Access/Start Authorization Antenna 1 (R138)
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 105
Mileage: 166112 km
Time Indication: 0
Date: 2013.01.30
Time: 18:41:48
Address 18: Aux. Heat Labels: None
Part No SW: 4E0 910 105 HW: 4E0 265 081 F
Component: Heizgeraet H06 0290
Revision: 0000000F Serial number: 00000009001484
Shop #: WSC 00000 000 00000
VCID: D9B313BD1002D31
1 Fault Found:
01406 - No Flame
000 - - - Intermittent
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 HW: 4E0 907 468 B
Component: Gateway H06 0070
Revision: 06 Serial number: 0100403517015F
Coding: FEFFFFFF2B7504
Shop #: WSC 02555 823 55447
VCID: E5CB2F4D2C7A671
1 Fault Found:
01207 - Control Module for Auxiliary Heater (J364)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 144
Mileage: 166090 km
Time Indication: 0
Date: 2013.01.30
Time: 09:57:40
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0409600
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
5 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 105
Mileage: 166112 km
Time Indication: 0
Date: 2013.01.30
Time: 18:41:48
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 105
Mileage: 166112 km
Time Indication: 0
Date: 2013.01.30
Time: 18:41:48
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 105
Mileage: 166112 km
Time Indication: 0
Date: 2013.01.30
Time: 18:41:48
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 105
Mileage: 166112 km
Time Indication: 0
Date: 2013.01.30
Time: 18:41:48
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 105
Mileage: 166112 km
Time Indication: 0
Date: 2013.01.30
Time: 18:41:48
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 HW: 4E0 919 158 B
Component: KLIMA-STG. FOND 015 0210
Revision: 00000014 Serial number: 00000000015239
Coding: 0000000
VCID: E1C33B5D38520B1
Part No: 4E0 910 772 A
Component: Sitzluefter FS H02 010
Component: Sitzluefter BFS H02 010
4 Faults Found:
02299 - Supply Voltage Seat Vent; Rear Driver Side
011 - Open Circuit
02300 - Supply Voltage Seat Vent; Rear Passenger Side
011 - Open Circuit
02291 - Control Module for Seat Vent; Rear; Driver Side (J674)
02292 - Control Module for Seat Vent; Rear Passenger Side (J675)
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0000631
Shop #: WSC 52388 133 92782
VCID: 2045FE59F3D8C29
1 Fault Found:
02596 - Rear Brake Pads Worn
008 - Implausible Signal
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 2
Reset counter: 105
Time Indication: 0
Freeze Frame:
Voltage: 5.69 V
Count: 61
Address 66: Seat, Rear Labels: None
Part No SW: 4E0 910 860 HW: 4E0 959 860
Component: Sitz Fond H06 0050
Revision: 00000000 Serial number: 5DS 008 795-01
Coding: 0000009
2 Faults Found:
02318 - Potentiometer for Lumbar Height / Massage; Left Rear (G424)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 4
Fault Frequency: 1
Reset counter: 105
Mileage: 30696 km
Time Indication: 0
Date: 2005.03.11
Time: 11:54:00
02319 - Potentiometer for Lumbar Height / Massage; Right Rear (G425)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 105
Mileage: 30696 km
Time Indication: 0
Date: 2005.03.11
Time: 09:53:27
I can confirm the car battery is on 100% also both remote controls have new batteries.
Old 4th February 2013, 10:56 AM
Could be that someone has been in at the module and not re-connected it properly.. And possibly hasn't reconnected the seats properly too, though that could be that the blower motors for the seat vents have broken.
Old 4th February 2013, 11:18 AM
wug wug is offline
Thanks for reply!
As for key-less issues seems like this is a common problem. I have seen on other Audi forums users complaining about it. I will bring the car this week to a highly recommended electrician working for Porsche Romania. Will keep you informed.
Old 4th March 2013, 07:53 AM
wug wug is offline
Update!
I have discovered that i am missing the memory buttons for driver seat. Since the car comes with memory seats according to ETKA and they are also present on the passenger side i am thinking that this could lead to errors for all Kessy antennas.
Seems like someone removed the memory buttons in the past and now is just a simple black plastic cover in the place. Since the car cannot see the memory buttons anymore could lead to this error? I was about to order the kessy module plus steering column module but i would like to eliminate all possible ways before i order.
Similar problem in the rear AC control. Car comes with ventilated seats for front and rear but in the rear the buttons allocated for ventilation are just simply plain black. The ones in the front are fine. So i am thinking at the same problem, since the rear AC control in the back is missing the command could lead to this errors.
Who ever think that a car from Germany with full inspection service book with Audi dealer can have this dodgy job going on?
Old 4th March 2013, 03:53 PM
Do you have the fingerprint reader? If so, then you won't have driver memory buttons, they only came without the fingerprint scanner.
Old 4th March 2013, 03:56 PM
wug wug is offline
yes, i do have fingerprint scan. So, you mean to save the settings for each driver i have to create user under MMI?
Old 4th March 2013, 04:20 PM
Exactly that.. so you won't have memory buttons, just the blanking plate.
Double check the module codings to make sure that it's set properly for that.
Old 7th March 2013, 07:51 AM
wug wug is offline
I have tried register myself as a user but i can only go till the moment "place the finger selected into the middle of fingerprint space". There is no message coming up or dirty sensor etc. The sensor is definitely clean. I deleted all previous users registered. What i am doing wrong?
S4 C4 Turbo Quattro
Old 8th March 2013, 10:06 AM
wug wug is offline
Pics
ID:	5719   Click image for larger version
S4 C4 Turbo Quattro
Old 8th March 2013, 04:20 PM
It could be a faulty module (or fingerprint sensor).
