Old 10th March 2013, 08:55 AM
Default rear fuse carrier should it switch off with the mmi
some time back before i got the OEM hybrid tv, i had a cheap aftermarket tv wired up to the fuse carrier in the left luggage compartment. which worked well as the power went of with the mmi. ie after a few minutes without engine it switches itself off
i have just added a dvd / media player and new monitors so did the same thing, this time though the power doesnt seem to go off with the mmi
i thought that the whole of that fuse carrier went off with the mmi, if not where would i get an ACC from, there no way im running a wire to the ignition from there.
