Old 19th October 2013, 09:30 AM
humdigadi humdigadi is offline
Default Climate control problem
Hi all,
The climate control on my D2 PF isn't working correctly. It doesn't matter what I set the temperature to, it blows hot air out of all of the vents apart from the those in the centre of the dash. I think I've tried all options but I just can't get it to work effectively. I know the air conditioning isn't charged (wouldn't hold pressure when it was recharged) but I would still expect it to blow the cold outside air when set to low but it doesn't.
Can anyone offer any advice?
Thanks, Matt
Old 21st October 2013, 02:00 PM
Not sure how the system works or the route the air takes but could be a sticking flap inside somewhere that won't allow cold air in.
Old 21st October 2013, 02:45 PM
^^ What he said.. If you have VCDS you should be able to test the motors.
Old 21st October 2013, 09:36 PM
Thank you for taking the time to reply. I don't have VCDS unfortunately but I'll look into it. I'm a bit of a newbie I'm afraid. I'll also have a poke around to see if anything is sticking. Thanks again.
Old 21st October 2013, 10:25 PM
If everything is quiet inside the car, with the fan speed low you should be able to hear some of the flaps move when you push the econ button. Also well worth a look at the Vagcom register as there could be someone close that might plug it in for you
Old 22nd October 2013, 04:55 AM
Vagcom register is HERE.
Old 22nd October 2013, 11:44 AM
Good idea, I'll have a listen. I know the flaps under the bonnet work, I've seen them open and close so it must be somewhere behind the dash.
There doesn't appear to be anyone that close to me with VCDS (I'm in Derby), Shark_90 is in the midlands but he doesn't seem to be a current member. How much does the equipment cost? I've tried reading the sticky about it but to a beginner it isn't that clear. If it's not overly expensive, I may invest in it.
Thanks, Matt
Old 22nd October 2013, 11:55 AM
I think most people on here would consider VCDS is almost as essential as the ignition key, unless you only let dealers work on your car and trust them implicitly.
When I got my first S8 (2002) I bought VAG-COM and a Bentley manual at the same time. The former (now updated to VCDS) has been and still is invaluable, the latter largely replaced by online resources these days.
Old 22nd October 2013, 11:59 AM
Shark_90 is Ben who runs Shark Performance http://www.sharkperformance.co.uk/contact.asp
They will likely want some money to do a scan, but probably a lot more honest than the Audi stealer.
Old 22nd October 2013, 04:59 PM
Well looks like I won't be getting a freebie then!! Thanks for letting my know PsYcHe.
I'll have an explore around and see if I can find anything mechnical that should be working in the first instance. At least the weather is heading in the right direction for this not to be too much of a problem!!
