Old 12th December 2013, 11:54 AM
Default MMI 2G DVD nav disc
My newly acquired D3 has the original 2003 navigation DVD installed. I acquired a 2013 ISO but all I get is check Navigation DVD error when I put it in. I only had a dual layer disc to hand, so used that burnt at the slowest speed I could on my MAC.
Should I just give up, or try a different DVD media?.
Old 12th December 2013, 12:30 PM
That isnt enough for these disks, you need certain types of burner that are able to change the bookmark type to DVD-ROM or it wont work also has to be a good quality DVD+R
Old 12th December 2013, 12:36 PM
As above, single layer media needed - it'll probably work off your mac and worth a try before attempting anything else
Old 12th December 2013, 06:04 PM
Try single layer, I use a Mac and it worked fine with +R and -R even using Toast or Disk Utility.
Old 12th December 2013, 07:41 PM
I use -R single layer and it's fine.. Though I do need to burn at 4x or less.
Old 13th December 2013, 08:31 AM
Yay, it works. Used Roxio Toast and burnt at 2x speed onto a single layer Verbatim DVD-R.
At last I have some local roads which were missing.
Old 13th December 2013, 10:48 AM
do you also have 3d available now or did you have it before
Old 13th December 2013, 10:55 AM
The MMI firmware currently installed is too old for that. I do have the three ISO's for the latest version, although I have not got around to running them through.
Old 14th December 2013, 10:47 AM
After trying to navigate 140 miles last night, part way through the route it stopped navigating and came up "check navigation dvd" again.
So I stopped at the next services and tried to get it to recognise the original 2003 one, which generated the same error when put back in. The system immediately recognises my copy and it seems ok, but its obvious the disk copy is not working perfectly. There is also no navigation audio on the 2013 version for some reason, just visual guidance.
I don't know if the reason the original older 2003 one no longer works is because the newer one has been used, and perhaps something has been updated. so I need to attempt to get a perfect copy of the 2013 version that works.
Old 14th December 2013, 11:12 AM
You may need the MMI software updated too, that could potentially be causing issues.
