Old 1st August 2014, 09:45 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Default VCDS Engine Messuring Blocks
Randomly trying things and stuff with VCDs and the car I started looking at the measuring blocks.
I noticed something that does not look right to me.
First off. What is at -40.5 degree?
Should the lambda sensors all be at 99.9%?
Anyone else not got the label file for 01 - Engine?
[center]
06 3.0TDI Quattro:
Options:
Old 1st August 2014, 01:26 PM
ScottD3's Avatar
Found it.
035 Temperature protection
1) Engine speed
At idle: 720 ... 820 rpm
2) Exhaust gas temperature before turbocharger
At idle: 140 ... 310 °C (with radiator fluid > 75 °C)
At full throttle: 540 ... 830 °C
3) Exhaust gas governing factor
At idle: 99 ... 101 % or 0.99 ... 1,01
4) Overall governing factor
020 AC compressor
1) Ambient temperature
[°C]
2) Vacant
3) AC compressor shut-off status 1
X X X X X X X 1 Vehicle starting off
X X X X X X 1 X Shut-off due to starting off state
X X X X X 1 X X Vehicle acceleration
status
X X X X 1 X X X Shut-off due to acceleration
X X X 1 X X X X Shut-off due to starting
X X 1 X X X X X System fault detected
X 1 X X X X X X Shut-off due to system fault
1 X X X X X X X Shut-off due to inadequate idling
speed
4) AC compressor shut-off status 2
X X X X X X X 1 Shut-off due to excessive coolant temperature
X X X X X X 1 X Shut-off by gearbox control unit
X X X X X 1 X X Shut-off by ABS/ESP control unit
X X X X 1 X X X Shut-off due to refrigerant pressure or
ambient temperature
X X X 1 X X X X Power reduction due to overheating
X X 1 X X X X X Shut-off due to fault in a radiator fan
X 1 X X X X X X Shut-off due to fault in both radiator fans
1 X X X X X X X Minimum on-time
[center]
06 3.0TDI Quattro:
Options:
