Old 9th March 2014, 07:50 AM
Exclamation Altinator whine ?....
Has anyone experienced a supercharger like noise from there 8 ?
I think the altinator is on its way out im going to take the belt off and run the engine without and see if the noise goes away I paniced and thought it might be the box ! But it dose it in neutral park and drive in time with engine revs.
Any ideas any one ?
Old 10th March 2014, 06:28 AM
No ideas ?
Old 10th March 2014, 09:34 AM
We once had a C220 Kompressor but it didn't whine so I don't know how that sounds but my A8 3.0TDi engine does whine slightly compared to other engines and has done since I bought it so would be interested how your test goes.
Old 10th March 2014, 03:24 PM
Does the belt not also drive the aircon and power steering?
Have you checked to see if turning thr aircon off makes a difference?
Old 10th March 2014, 07:29 PM
darrenjoe90's Avatar
Mine also make this noise but only after i have put my foot down. Let me know if you find out what it is ?
Audi S8 Phantom Black
Old 10th March 2014, 09:47 PM
That's just the wails of the dead dinosaurs you're burning screaming through the years
Old 11th March 2014, 06:28 AM
mannyo mannyo is offline
Could be the aircon compressor, try shutting the whole system off or try selecting econ mode to disable the compressor.
Manny
Past
Old 14th March 2014, 02:24 PM
Tried all of the above it definitely dose it in every selection D P R N S all of them and ive also figured its definitely not the gear box because if I nock it in two neutral on the move its still only in time with the engine revs not road speed :s
Confused now ...
Can only be eather
Air con pump
Power steering pump
Altinator
Or auxiliary belt tentioner
Well...I guess any way
Old 25th March 2014, 05:13 PM
Mine is the same Daviebike. But not aircon as still does it with that declutched, and could be the vacuum pump for the brakes (and maybe EGR), or hydraulic pump in the auto box as that runs in N too.
Old 26th March 2014, 02:16 PM
A8L Chick's Avatar
A8L Chick A8L Chick is offline
Mine does it but goes off when I shut the a/c off. Must be a/c pump in my case. I've got used to it, did **** me off for a while though.. I'm sure it'll **** me off again at some point when the a/c packs-up
07 Silver D3 A/S8L Quattro S8 front end, Xenons, Bose, Bluetooth, Voice Control, Autodim mirrors, Heated folding mirrors, Double Glazed Windows, Electric Rear & Side Blinds, Black leather Comfort Seats with front memory seats & mirrors, Front & rear heated seats, Interior/Exterior light pack, TV.I.M, AMI, Parking sensors Front & Rear, Air suspension (soon to be lowered), Keyless entry & Start/Stop, 4 zone climate control, Power Boot Open/Close.
