Old 12th May 2014, 02:32 PM
Zip's Avatar
Zip Zip is offline
Question front inner tyre wear...?
Hi,
Rather disturbingly, both my fronts are showing a bit of canvas along the inside edges, the rest of the tyres with plenty of tread left.
Just ordered myself a couple or PilotSports to replace them with, but would be keen to understand why they are wearing like this, or is it just a Audi S8 "feature"?
Some of my lower front bushes are quite hard and cracking....would this contibute?
Zip
Old 12th May 2014, 02:44 PM
They seem to suffer from too much camber on the front, and it isn't adjustable. I over came this by having the toe set IN slightly to compensate and wear right across the tyre.
It could be the arms showing there age or the constant S not set correctly when tracked.
Old 12th May 2014, 03:19 PM
As Dezzy has said really - if you're doing a lot of town work it'll make it worse. My fronts lasted about 16k miles and weren't down to the cords - that involved a lot of town driving too. It's definitely worth rotating tyres diagonally if they're replaced as a set of 4. If replacing pairs get the new tyres fitted on the back first and they will last longer once swapped to the front.
Worth getting a proper alignment check done and worn arms will give dynamic changes in suspension setup which won't be picked up on a static alignment so if you know they're shagged it's probably best to get them changed before paying 2 hours labour for an alignment to be done.
Old 12th May 2014, 03:44 PM
Zip's Avatar
Zip Zip is offline
Question
...so why do whole arms get changed, and not just new bushes pressed in??? How do the arms "wear"? They're solid bit sof metal!
Zip
Old 12th May 2014, 03:55 PM
You can get the bushes and press them in if you want to. I bought cheap ebay arms and changed them on the drive one side at a time. The bushes i couldn't buy for the price i paid the full set of cheap arms and my press is an engineers vice . So for me i swapped out a side at a time.
Old 12th May 2014, 04:23 PM
Zip
By arms worn I mean the bushes - problem is the bill to replace the bushes on existing arms (and risk that balljoints where fitted are worn as well) will be higher in labour than cost of complete replacement arms. Different if you're doing the work yourself but you'll end a hydraulic press I suspect
Have a search for Meyle on here and there's threads about replacement options. Mine's coming up to 60k miles and has had all 4 upper arms done but lower arms are all original still
Old 17th January 2015, 08:05 AM
Sir WIll Sir WIll is offline
Just been in to replace the rear tyres as they were wearing low especially on the outside edges.
Checked the front tyres and guess what!
Front tyres have 2 to 3mm across the main part of the rubber no problem, very inside edge that you can hardly see just down to the cords!
Arms are all pretty recent so time to up the psi from 36 to 40 and find a good local company to do the alignment (Constant S and I have been reading all about!)
Old 17th January 2015, 11:16 AM
My previous S8 was suffering the exact same inside wear on the front tyres, however I new it was misaligned after having some work done. I got a new set of tyres, and a proper alignment at Audi and it didn't do it since. Now the same tyres are on my new S8 and still wearing reasonably evenly.
I don't know how helpful this is.
Old 17th January 2015, 11:20 AM
I certainly would not trust Kwik Fit for the alignment, it would be interesting to know how much Audi charged you to do it?
Old 17th January 2015, 11:26 AM
I had the same problem with my s8 for my first couple of years, and went through several sets of fronts surprisingly quickly. Since then, I've got my local Kwikfit to do the alignment on their Hunter alignment machine every year, and the tyres have been fine since - a worthwhile investment of c.£50 from memory, and I've always found Kwikfit to be excellent.
