Old 24th June 2014, 11:31 AM
Zip's Avatar
Zip Zip is offline
Question Shorted ciggy lighter socket...?
...I went to plug in my phone charger this morning, and the spring loaded pin had fallen out. Damn.
Anyway, reassembled, and the front socket now doesn't work. The one in the rear does. Could I have shorted something out? Is there a fuse somewhere I could have blown?
Everything else seems fine...
Ta,
Z
Old 24th June 2014, 12:30 PM
Conquistador's Avatar
I'd check or replace the fuse. Not sure what position or where the box is located on the D2 unfortunately.
I plugged a phone charger into mine once and it started sparking. Had to pull over immediately, whip the manual out to locate the correct fuse to pull out and then retrieve the connecting pin from the socket once everything had cooled down!
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 24th June 2014, 08:58 PM
I'd check the fuse box on the drivers side end of the dashboard. The door covers it when closed. You just prise the cover off to open it
Old 24th June 2014, 09:10 PM
Wrong place, D2 fusebox is by the drivers right foot. Panel is covered in carpet and held on by a large plastic knurled wheel that you just spin anticlockwise to release.
Fuse layout in drivers handbook which I don't have to hand or I'd check it.
Old 24th June 2014, 09:17 PM
This might help:
Looks like fuse holder 3 (yellow), fuse number 3, 15A.
Old 24th June 2014, 10:19 PM
Zip's Avatar
Zip Zip is offline
Thumbs up
Cheers gents. Will check in the daylight tomorrow morning.
Zip
Old 25th June 2014, 10:00 PM
Zip's Avatar
Zip Zip is offline
Thumbs up
Yep ... Yellow number 3 blown.
Thanks again,
Zip
