Old 5th October 2014, 09:14 AM
dizzlebizzle dizzlebizzle is offline
Default Wanted: D3 Rotary Push Button for MMI Control Console
Hi,
I'm wondering if anybody has a spare rotary push button for the MMI control console that isn't worn. Mine is worn slightly... not a massive deal I know but I find it hard to live with this kind of thing.
Some advice on how to get the button on and off without damaging anything would also be greatly appreciated.
Regards,
Daniel
Old 5th October 2014, 10:15 AM
When I got mine the rubber coating in the centre of the button was peeling, it looked bad. So I just removed the rest of the rubber. It's black plastic underneath and it now looks fine. My only mod
Old 5th October 2014, 08:15 PM
I think the center knob may be available as a seperate (and thus cheap) part number item....
You'll need to remove the whole MMI control panel to get to the underside of it to remove.
The wood trim surrounding the center console will pull off reasoably easily, making access to the MMI panel straight forward..
