Old 5th October 2014, 09:09 AM
dizzlebizzle dizzlebizzle is offline
Default D3 Chrome Window Trim - Cloudy White Marks
Hi,
I've recently purchased a 2007 Audi A8 3.0TDI Quattro and I've noticed the chrome trim around the windows, particularly around the rear quarter glass, has cloudy white marks on it... some form of corrosion I'm guessing.
I'm just wondering if anybody knows how to get rid of it... any ideas?
Regards,
Daniel
Old 5th October 2014, 09:21 AM
Its new trim or wet sand the clear coat off and re apply
Old 5th October 2014, 09:31 AM
That's a shame... I suppose I will have to live with it!
Thanks for the information though.
Regards,
Daniel
Old 29th October 2014, 01:48 PM
Deek Deek is offline
You could get it wrapped in satin chrome finish
Old 29th October 2014, 02:12 PM
I keep thinking some sort of heat gun might work, but would want to try on a test piece off the car first.
Old 29th October 2014, 02:43 PM
Afraid this problem is not new and afflicted D2s (search "milky trim" and you will see along history) of which this thread is one:
http://forum.a8parts.co.uk/showthrea...ght=milky+trim
I have tried the wet and dry and re-laquer approach. It is 1). hard work and 2). not long lasting.
I tried finding out about re-anodising (which can of course be done in a range of colours if you wish) but it wasnt something i followed up.
Old 29th October 2014, 03:14 PM
Notorious on here got his D2 trim powder coated, sure he will be along shortly to explain, if not drop him a PM
Old 29th October 2014, 03:47 PM
I tried the WD40 method (seen online in various forums and I used GT85 not WD40) and that made some of it noticeably less obvious, presumably the surface-only damage.
On the other hand it just highlighted the bits that had deeper damage.
Old 1st November 2014, 07:24 PM
Thanks for the responses.
It's not that bad. I will just live with it, I don't want to try something and risk making it worse.
Regards,
Daniel
Old 3rd November 2014, 11:24 AM
BADES's Avatar
BADES BADES is offline
I took a dremel type rotary to mine with a polishing head and Megs metal polish.
Finished it off with a FEW coats of Chemical Guys Jet Seal to protect.
Its been a few months now and it seems to be holding up ok - its a lot better than It was before, although not flawless.
Phantom Schwarz D3 2006 3.0 TDi remapped
Valcona Black Leather, Bose, 19" BBS, VCDS Lowered, Xenons, Bluetooth and still lots to do...
Blue 2007 Audi Q7 3.0 TDi S-line
Heated Seats, Leather/Alcantera, Auto Boot, Sat Nav (NOT WORKING !), Bluetooth, 20" alloys.
