Old 26th November 2014, 12:01 PM
Default Strewth !!! D3 S8
What does everyone make of this one then?
http://www.ebay.co.uk/itm/2008-08-Au...d=737741655351
Old 26th November 2014, 12:23 PM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Problem developed in August this year with Piston 1 failing inside the engine causing minimal wear to the engine. Car does start but recommended NOT to start
How do they know?
[center]
06 3.0TDI Quattro:
Options:
Old 26th November 2014, 12:29 PM
ScottD3's Avatar
If anyone wants to know the MOT history.
There are no later tests for this Vehicle.
Most Recent Vehicle Details and Test Summary applicable to this Registration Certificate document reference number.
Registration mark:
OU08WJZ
Make/Model:
AUDI / S8
Colour:
BLACK
VIN/Chassis No:
WAUZZZ4EX8N008657
Approximate date of first use:
03/03/2008
Type of fuel:
Petrol
Date of test:
09/05/2014
Certificate issued (Pass)
Odometer reading:
110,753 Miles
Test number:
378969924171
Test expiry date:
08/05/2015
Full Test History, starting with first recorded vehicle and test results
Registration mark:
OU08WJZ
Make/Model:
AUDI / S8
Colour:
BLACK
VIN/Chassis No:
WAUZZZ4EX8N008657
03/03/2008
Type of fuel:
Petrol
Date of test:
21/01/2011
Odometer reading:
43,236 Miles
Test number:
548431021097
Test station name:
CHURCH WHARF GARAGE (1971)LTD
Test station number:
6561B3
Test station telephone number:
01204522235
Test class:
IV
Test expiry date:
20/01/2012
No Advisory Notice issued
Date of test:
21/03/2012
Certificate issue refused (Fail)
Odometer reading:
74,116 Miles
Test number:
235011382041
Test station name:
MOTEST SWINDON
4786AJ
01793 613448
Test class:
IV
Reason(s) for refusal to issue Certificate
Offside Headlamp not working on dipped beam (1.7.5a)
Offside Headlamp not working on main beam (1.7.5a)
Date of test:
22/03/2012
Odometer reading:
74,124 Miles
Test number:
418412982056
Test station name:
MOTEST SWINDON
4786AJ
01793 613448
Test class:
IV
Test expiry date:
21/03/2013
Chip in windscreen drivers side upper
Date of test:
22/03/2013
Odometer reading:
100,594 Miles
Test number:
206271583024
Test station name:
KINGSDOWN MOT CENTRE
1ALJ37
01793831400
Test class:
IV
Nearside Rear Tyre tread depth below requirements of 1.6mm (4.1.E.1)
Offside Rear Tyre worn close to the legal limit (4.1.E.1)
Date of test:
22/03/2013
Odometer reading:
100,652 Miles
Test number:
749711083055
Test station name:
1ALJ37
01793831400
Test class:
IV
Test expiry date:
21/03/2014
Date of test:
09/05/2014
Odometer reading:
110,753 Miles
Test number:
378969924171
Test station name:
CAIN MOTORS
18562
02085395026
Test class:
IV
Test expiry date:
08/05/2015
Nearside Front Upper Suspension arm has slight play in a pin/bush (2.4.G.2)
Offside Front Upper Suspension arm has slight play in a pin/bearing (2.4.G.2)
This completes the test history for the above vehicle as recorded on VOSA's MOT Computerisation Database
[center]
06 3.0TDI Quattro:
Options:
Old 26th November 2014, 12:42 PM
Done some impressive amount of miles in the last few years.
As for the piston damage that could be serious money to sort out.
I wouldn't touch it thats for sure, not unless it was getting broken.
Old 26th November 2014, 01:19 PM
Depends on the cylinder damage really.. Even if it was 3k to sort, still a bargain... But.. You'd always be wondering if any of the others were thinking about it.
Old 26th November 2014, 03:21 PM
roberto's Avatar
roberto roberto is offline
im seriously starting to wonder about the reliability of these engines now
if it was £5000 i would 4.2 tdi it (conversion time)(done it before)
Old 26th November 2014, 06:38 PM
audifin audifin is offline
Interesting... so you would have 4.2TDI with S8 looks, brakes and suspension. Are there any other differences?
Old 27th November 2014, 06:37 AM
ScottD3's Avatar
He would have a 3.0TDI with S8 looks.
[center]
06 3.0TDI Quattro:
Options:
