Hi Just a quick one all
Just to see if anyone would know it the new 2014 disk would work with my current SW of 0770 which is very old. Told that it should but would just like to check before ordering. I have a set of Update disks to use at somepoint. Also about to order the 1100 update disk as I don't want to jump to far with the updates. Planning to do it when its a bit warmer outside, but would still like to use the new 2014 disk....not to worried about 3d on the maps right new. Thanks very much ALL ![]() ![]() |
Satnav disk should work.
I read on a German forum before it was released that there was an Audi note that said it requires 5770.
Yep was not sure I did check with the seller and he thinks it sould be ok with the old SW 0770. I will update at somepoint next year .....a warm summers evening sounds like the best time I think.
I updated mine and I was originally on 0770, satnav worked fine if a little slower but that dissapeared when updating to 5570, you will still not have 3d maps though untill the mmi is updated.
