Old 29th December 2014, 09:39 PM
carmel120 carmel120 is offline
Default a8 d3 headlight bulb
Hi people I've done a bit of searching on here for replacement from the standard bulb to led on the sidelight and the front fogs which led bulbs do I need, im not doing the drl option
cheers trev
Old 30th December 2014, 09:26 AM
Side lights are W5W 12v.
Fog lights are H11 55W. Or H7 55W, best to check (thanks snapdragon)
As for replacing these with LED's I can't give any recommendation, but I would think they would have to be Canbus error free. Quick search on google and ebay gives lots of choices.
Sides:
http://www.ebay.co.uk/itm/2-X-ERROR-...item58ae8d8d5b
Fogs:
http://www.ebay.co.uk/itm/2x-H11-CAN...item339a2d6f73
Matt
Old 30th December 2014, 09:38 AM
My fogs are H7, some are H11, so best to check first.
You will get bulb out errors though unless you get some sort of electrical shunt installed.
Old 31st December 2014, 05:43 AM
cheers guys is there any that doesn't give any errors
cheers trev
