Closed Thread
Old 21st January 2009, 06:07 PM
Default Lights Repair Sticky
Here we will post links to lights related solutions. This post will be edited by an Administrator when a new solution is found either within this forum or elsewhere on the Interweb.
To Start the Ball Rolling here are some classic links from Paul W's Audipages. This site can't be recommended enough as a gold mine of information about you 8.
LIGHTS
Hat Shelf Rear Light Lamp Replacement - Audipages
Headlight Polishing How-To - Oli of Tyresmoke via Audipages
2001 S8 - Xenon Range/Headlamp Warning Solved!
- GlynH on Tyresmoke
Headlamp & Fog Light Lens Refurbishment - Iyole
Fixing broken mounting bracket on headlight cluster - CtL
D2 lights and lamps spreadsheet - David'S8
Remember, if you find a solution to a problem you've had or others have posted on the web let an Admin know (PM or email) and we will add it to this sticky.
Old 3rd January 2015, 10:17 PM
Sticky Updated!!
Closed Thread
