Old 9th April 2016, 02:06 PM
Rick Rick is offline
Default Tpms help please, new sensors fitted
Alright lads.
Had new tyres put on today so changed the old dead tpms units for new ones.
Im having trouble getting them to register.
Can someone do me an idiots guide to enabling and coding in vcds pretty please.
This is what i have at the mo showing
Lovage xxx
Old 9th April 2016, 02:36 PM
Coding on that screen is fine, you need to check coding in 17 instruments first pair of non 0 digits should be 48
Also check the coding in control head if you are missing the menu item from the systems dialogue on the mmi
Once you have that all sorted go into the tyre pressure menu and choose initialise then go for a decent drive
Good luck
Old 9th April 2016, 03:03 PM
Yep all that is good.
So its a case of give it a drive? Came back across town once wheels were done. Should i hit the dual cabbageway later?
Its telling me to put key in and turn ignition on to configure the system, could it be do that and wait for 5 or 10 mins?
ID:	13075   Click image for larger version
ID:	13076   Click image for larger version
ID:	13077   Click image for larger version
ID:	13078   Click image for larger version
Old 9th April 2016, 03:15 PM
From starting the process when I did mine yesterday it took a 15min approx drive to get it to register.
Old 9th April 2016, 03:18 PM
Oh ok brilliant. Me being impatient then! Cheers Del.
Old 9th April 2016, 04:11 PM
Norretal's Avatar
Norretal Norretal is offline
You changed yours again Del, or is initialising necessary after some activities?
I'm still debating whether to have mine sorted when I fit the original wheels or just do without them.
Audi TT - 2015 - Ultra
Old 9th April 2016, 04:14 PM
Took the wellies off and fitted the running shoes back on so had to code it all back in Ron
Old 9th April 2016, 04:32 PM
Norretal's Avatar
Makes sense now, didn't realise you'd fitted winter wheels Del, cheers
Old 11th April 2016, 07:55 AM
kele kele is offline
Same here in that I just swapped off my winters for summer tyres. Taking the opportunity to have the wheels refurbished. Problem is that now I have no clue which wheel came from which corner... Does anyone know if this needs to be coded - or can this be set through the "initialise" routine on the MMI?
2012 A6 3.0 TDI Avant, Silver, 7 Spd STronic, Bose, ACC, Advanced Parking Camera, Power close / open tailgate, Side and Lane Assist, AMI & Jukebox, Adaptive lights with corner and high beam assist, Through load with ski bag, Audi pre sense plus, sports diff and sport suspension, Panoramic roof, Storage pack, MMI touchpad and VIM, etc. Oh and now retro fit rear seat entertainment
2019 BMW I3. Heat pump, Winter, professional and comfort packs, Harmon Kardon, autopilot
2022 Mercedes EQC 400
Previously: 2009 S8, Silver, B&O, Ceramic Brakes, Advanced Parking Camera, VCDS
2008 A8 3.0 Tdi sport, B&O
Old 11th April 2016, 08:48 AM
Doesn't matter as the system learns after your tell it to learn again
