Old 11th February 2015, 08:24 PM
mazm3 mazm3 is offline
Default Cd changer error?Options please..
A8 4.2 1995
Each time i press the mode button on the standard stereo it just comes up error. Doesnt even try to read discs.
Any ideas? Can i use an ipod on the cd changer lead?Is that possible?
I do miss the sound quality of the cd changer through the bose compared to the radio!
It is the rectangle delta radio BTW
https://www.google.com/search?q=a8+d...2F%3B800%3B600
Old 11th February 2015, 08:41 PM
There are various devices that can be used in place of or alongside the CD changer, depending where/how you wire them in. e.g. XcarLink.
Where are you? I have a spare CD changer that a member here gave me some time ago. Easy enough to access in the boot and swap the leads over to test.
Old 11th February 2015, 08:51 PM
Hi, im located in Portsmouth! Just checked out the x car link site. Seems i can use my ipod! Might be a better solution than the cd player
Old 11th February 2015, 09:02 PM
Someone on AudiSRS was selling one possibly relevant model (there are several) http://audisrs.com/about57925.html
Old 12th February 2015, 09:02 AM
Just get one of these for the D2 as is cheaper. Just using one atm for an installation i am doing using a parrot via line in ..
http://www.ebay.co.uk/itm/2509065964...423%26_rdc%3D1
Old 1st March 2015, 04:58 PM
Bandycoot Bandycoot is offline
I'm getting exactly the same problem on my S8. It started as an intermittent problem on one or two discs and would clear itself. The other day an error message came up on all discs and now it won't clear. Is the only answer a replacement changer or is a fix possible? It couldn't have happened at a worse time as I'm leaving Dubai and coming back to blighty so I'm selling the beasty.
2001 D2 S8. Volcano black. KW Variant 1 coilovers. EBC Turbo grooved discs with Yellow Stuff pads. 19 inch R8 replica wheels with 255/35/19 Michelin Super Sport. In the UK, 1990 Audi 90 2.3 20v Quattro with just 65,000 on the clock and in mint condition.
Old 1st March 2015, 05:33 PM
mannyo mannyo is offline
If the mechanism has stuck then replace is really the only option, if the CD player is still loading discs before the error it could just be a dirty laser. I've had some success using these CD laser cleaning discs you can buy with little brushes on them in the past.
Manny
Past
