Hi Guys,
Could anyone throw any light onto the fault code detailed below. Is this the central locking pump gone south. It will not work at all, no noise from the boot either. Car can be locked and unlocked manually using the key. rear doors and passenger front door have to have the buttons pressed down and locked. Address 35: Centr. Locks Labels: 8D0-862-257.lbl Control Module Part Number: 8LO 862 257 Component and/or Version: ZV-Pumpe, DWA, Funk Software Coding: 10184 Work Shop Code: WSC 65535 VCID: 112DB17771F9 5 Faults Found: 01367 - Central Locking Pump Run Time Exceeded (Likely Leak) 35-00 - - 01371 - Unlicensed Version. Not all DTCs 35-00 - will be decoded. 01372 - Unlicensed Version. Not all DTCs 35-00 - will be decoded. 01370 - Alarm triggered by Interior Monitoring 35-00 - - 01368 - Unlicensed Version. Not all DTCs 35-00 - will be decoded. Also the Airbag light came on again, but this time its the rear passenger side seat sensor. Is there a way of fitting a resister to the rear seat sensor? Address 15: Airbags Labels: Redir Fail! Control Module Part Number: 4D0 959 655 C Component and/or Version: Airbag 7 Audi D02 Software Coding: 00224 Work Shop Code: WSC 02314 VCID: 326F1EFBD4BF 1 Fault Found: 01216 - Seat Occupant Sensor; Passenger Side Rear (G178) 32-10 - Resistance too High - Intermittent Many thanks for any responses. Barzya8
2002 S8 Final Edition, Avus Silver with Red leather interior Guildford, Surrey Tiptronic with Sport mode button. Sony rear entertainment package. Bose sound system. Audi Navigation Plus. 20 inch Final Edition alloys Full Cat Back Stainless Milltek exhaust, giving a great V8 burble ![]() ![]() 1997 A8 Quattro Sport - Now sold when S8 FE purchased ![]() |
Just as an addition, I can now hear the pump working, but not opening or closing any doors. It runs for about 10 seconds and then stops when using the key only. Nothing happens when trying to use the remote on the key.
