Go Back   A8 Parts Forum > A8 D3 > D3 - Common Faults
D3 - Common Faults Quick links to all known common faults and their solutions
Old 1st March 2015, 03:55 PM
kmthor kmthor is offline
Default Rear Demister
Hi Guys
the top 2 lines of my rear demister are the only ones to work so i know there is power getting to it. Dose anybody know how to check or fix this problem?
Old 13th March 2015, 08:08 AM
3.7 slp 3.7 slp is offline
Originally Posted by kmthor View Post
Hi Guys
I have just the same problem with mine. Been that way since I have had the car. I can see from the outside where the glass has come away from the laminate. Its very slow to clear the screen and when it does it's only the top two lines and if I'm lucky the two bottom ones.
Old 13th March 2015, 09:08 AM
Depends which kind of demister you have. If it is painted one on the inner surface of the window you might be able to repair broken traces with silver paint. If it is built in barely visible lines inside the glass then only option is new glass. I have the one with built in heater inside of glass so out of luck. It is only about 1/3rd working from the middle up on mine.
Old 13th March 2015, 12:47 PM
mine is the older one the problem is access the bit you need to get to is behind the trim and i cant see how to take it off.
Old 1st April 2015, 12:50 PM
i took the trim out on saturday this may help somebody
you have to take the roof trim above the back screen off first (it just pulls out but be careful not to break the plastic clips) take the hadle off and the coat hook out. note there is a screw for the coat hook and a bolt behind the hook unit, take the bolt out above the back window pull carefully toward you to release the metal clips and then pull toward the front and its off..
hope this helps
