Old 8th July 2014, 05:04 PM
fletberbill fletberbill is offline
Default Speedo has packed up
Hi all. a couple of weeks ago my speedo packed up on a short trip and then started working again.
Well this morning it has decided to pack up again and the same on the way home from work.
Also since the speedo packed up my fuel gauge seems to be fluctuating up and down slowly.
Any help much appreciated.
Oh yeah it's a PF 4.2 on a 99 plate
Old 11th May 2015, 07:45 AM
ahd91 ahd91 is offline
Sorry to revive an old thread, but I'm having this issue too. On first switch-on, the fuel gauge fluctuates, and the speedo is dead. Once the car is warm, fuel gauge dies altogether, and the speedo springs back into life.
Old 11th May 2015, 08:07 AM
andycaca andycaca is offline
dodgy earth?
what does a scan with VCDS tell you?
2001 S8 D2
Old 11th May 2015, 09:22 AM
Not been able to scan it yet; booking in at some point this week.
Old 11th May 2015, 11:19 AM
Dave McB Dave McB is offline
I know that on BMW's the speedo doesn't work if theres an abs issue..
Could this be the same??
Old 11th May 2015, 11:38 AM
I could certainly see how the ABS wheel speed sensor could affect the speedo - but I don't see how this would also affect the fuel gauge?
I can live with no speedo for a couple of mins, but as things are I'm going to have to keep a record of what fuel is in the car, how far I've travelled, and hope that the MPG readout is somewhere near accurate.
Old 11th May 2015, 12:52 PM
I can confirm that ABS ECU issues can stop the Speedo working as I have seen this recently on a D3 and I would imagine it is the same on a D2. Heat from the engine can also cause the ECU circuit board to not make good contact soldering wise on some engines, depending on where the ECU is located.
Old 11th May 2015, 02:28 PM
Will get it scanned ASAP then.
Just disconnected the battery and left for 10 mins. This appears to have temporarily fixed things.
