Old 11th May 2015, 08:49 PM
oldnick oldnick is offline
Default I give up ...change the radio !
having struggled to cure my parasitic drain on the ICE circuit and hunted the internet for the most likely reason , it seems that the concert radio is most likely the culprit , a not uncommon fault
so I have come to the conclusion that spending a few euros might be the way to find out
however , here in france A8's [ mine being a 2000FL ] are rare beasts [ at up to 10 years old the cost to register in my name would be about €1k + about €2k if new but reducing by 10%pa after that ..you didn't think we got away with it paying no road tax , did you ? ]
so I am looking around at what I could fit , lots of A3 radios but they appear to be about 1.5 DIN 0r maybe 2DIN ...little else ; can anyone suggest what might fit on a plug and play basis ? in addition many are offered without code , that involves crossing the palm of the stealer ? how much ? and would my car accept another code ...the current radio seems happy to read the code off the ECU when I unhitch the battery , would that continue with another radio ?
and it also seems intuitive that you can swop over the fascia to fit your dashboard ...or can you ?
of course it would be nice to change to a double DIN and fit a sat nav , but with the aircon where it is that sounds like more time and expense than I would be willing to encompass !
anyhow , will look around and rely on good advice appearing here !
it seems intuitive
Old 12th May 2015, 12:21 PM
andycaca andycaca is offline
you could get a double din fascia and upgrade to a RNS-E.
someone on here put pictures up, spend a few hours using the search.
i have gone from a RNS-D to RNS-E and its bloody marvellous. the upgrade path from D to E is fairly straightforward and just needs a couple of adapter plugs and two wires soldering.
the concert upgrade might be more involving!
2001 S8 D2
Old 12th May 2015, 03:05 PM
or you could see if our forum sponsors have another concert radio you could try which would be a direct swap and may not cause such an issue?
Old 15th May 2015, 03:46 PM
had a change of plan , took out everything attached to this circuit in any way , radio right out , all connections
must be the wiring , so no point changing the radio or anything else
change the car maybe ?
