Old 4th August 2015, 11:21 PM
3.7 slp 3.7 slp is offline
Default random battery drain the
Had a now battry fitted about a year ago now I'm sshowing 10 on my meter most mornings
I have replace the END and not been of much help. The main meter look to be charging up on on the Battery screen. Would anyone had any ttime on here ti start looking with this would
thanks very much
Old 5th August 2015, 06:12 AM
first , when you fitted the battery did you have it coded in.
secondly check the details of this to see if your car needs a software upgrade
http://www.audi-resource.com/mmifalsewarn.php
Old 5th August 2015, 12:37 PM
Thank you for the reply
Yep had it coded up ok
I also have had the BEM unit replaced with an 2006 unit which would have the sw update .....still the same...
....I do have very old MMi SW which is 0770 I think
Old 5th August 2015, 05:07 PM
if you have vcds or even an outut file from it after your bem was fitted then you can check the s/w versions.
