Old 7th July 2016, 06:13 AM
Ameiseuk's Avatar
Ameiseuk Ameiseuk is offline
Question Oil cooler rebuild
The rebuild continues......
Decided based on some of the experiences here to pull the oil cooler out of the S8. Heads are already off so access was easy.
The only time consuming part was the Krypton Factor challenge of how to get the unit out of the engine bay once unbolted!
Oil cooler plastic pipe was in pieces, broken off at both ends. I have one of the machined pipes on order from the states so thats going in as soon as it arrives.
I set about fitting the o-ring kit last night, all sorted apart from one small o-ring approx 10mm OD. Anyone know where this fits on to
ID:	13781   Click image for larger version
Daily drive:
Current 'Project':
Previous 'Projects':
2000 Audi S8 FL
www.whall.co.uk
Old 7th July 2016, 08:36 AM
Is that for the oil filter drain plug?
Old 7th July 2016, 10:30 AM
Ameiseuk's Avatar
That could be it!
Its too small for the water pipe coming from the back of the block
I'll have a look this evening and see if it is
Daily drive:
Current 'Project':
2000 Audi S8 FL
www.whall.co.uk
