Old 6th December 2015, 06:38 PM
Default D2 headlight fault warning light
I've not had this before, but my S8 was showing an orange headlight warning today - "dynamic headlight range control faulty". Any one on here know how to fix this?
Old 6th December 2015, 06:43 PM
Probably a broken arm on the sensor (or he sensor has failed electrically) located between the frame and the suspension. Try VCDS to establish which of the 2 sensors (front/back) is faulty.
Old 6th December 2015, 07:50 PM
Cheers David - in that case I'd better get my VCDS port working too
Old 6th December 2015, 09:34 PM
If the arm is broken its pretty obvious - just stick yer heed underneath and look for a small black box with an arm on the subframe connected to a link mechanism on the suspension arms.
Old 6th December 2015, 10:16 PM
if its not physically broken the innards might be goosed, one of these is what you need, much cheaper than Audi if you don't mind non genuine parts, have one of these on mine and its been fine for a couple of years now
http://www.ebay.co.uk/itm/2908362594...%3AMEBIDX%3AIT
Old 7th December 2015, 07:38 AM
Yes, I bought the same one and it's been fine
