Old 4th January 2015, 06:03 PM
Default Super Smoky Thermotop Auxiliary Heater
Today, I started the engine while I put warm water over the windows and frozen-shut doors and noticed that after a few minutes the auxillary heater was very smoky.
As I usually drive the car straightaway up to 40mph maybe it is normal and dissapates as I'm driving. Do you think this is normal or it needs taking out and servicing? There are no fault codes, but I didn't have chance to check the live data at the time.
https://www.youtube.com/watch?v=4xxmNlDGC4w
Old 4th January 2015, 07:16 PM
I've noticed some smoke before when idling my TDi's. Like you say, you normally don't notice as you drive off fairly promptly. Possibly more noticeable in the cold weather too ?
I wouldn't be too worried personally.....
Old 4th January 2015, 08:09 PM
Johnmed's Avatar
Johnmed Johnmed is offline
Do the A8 TDis have webasto heaters? My old A2 did, the later models had auxiliary electric heaters.
If so, that's completely normal behaviour for a webasto. Or maybe I'm barking up the wrong tree.
2007 Mini Cooper S R56
Old 5th January 2015, 06:06 PM
Yup, The A8, and A6, Q7 and probably others all have Webastos as standard when its an oil burner...
Old 5th January 2015, 06:22 PM
Thanks for the replies. I'll not worry about it but may do the auxiliary waterpump mod this summer so I can use it as a parking heater. The pumps are less than £60 shipped these days. The two pipes are about £15 each from Audi. While it's out, I'll give it a good clean inside.
Old 5th January 2015, 07:28 PM
Johnmed's Avatar
I'm surprised the later cars didn't/don't have auxiliary electric heaters like the A2s. It's a good thing though, as the electric heaters do not heat the engine coolant, like the webastos.
