Old 30th December 2015, 10:58 PM
Lee S Lee S is offline
Default VCDS Questions
I really want to do a couple of VCDS tweaks, but for some reason I can't.
I'd like to change the EPB so that it releases WITHOUT having to have the seatbelt on. I need a security code for it though and none pops up. Is there a generic code or do I have to contact Ross-Tech?
Needle Sweep - I have NO long coding at all on virtually all of my modules. The instrument block has none for sure. Does this mean my cluster wont do the needle sweep or is there another way of coding it in?
I have done the VIM and also the hidden menu and activated the battery meter. I intend to lower it by maybe 20mm or so too via VCDS, but that's for a sunny day later on.
I'm also curious as to how to select some of the built in module tests rather than run through them all sequentially. The selective radio button is greyed out. I have an issue with the Aux Heater "no flame" but can't select a specific test and would have to cycle through them all. Is this safe?
Seems I'm a bit limited to what I can do on my car (MY2010 D3 QS 4.2TDI) with this VCDS. Or I'm a bit thick...
Lee
2017 Nissan Leaf Tekna
