Old 15th November 2016, 01:44 PM
Default 2006 A8 For Sale
My beloved for 6 years D3 is finally up for sale so I thought I will give forum members a first glance before it goes online elsewhere. I would really prefer to sell it to someone who will appreciate the ton of work and money put into this car.
By few described as spoiled and pampered to silly levels such as 6-7 hours clean every few weeks.
By the best Audi garage in London described as the driest V8 (no leaks whatsoever, ever) and one of the best looked after A8's.
Attended Annual Owners Meet twice where on both occasions all attendees scored it as the 2nd Best D3 during the event (on both occasions lost to S8's ).
Here it is story of my 8...
It is a 2006 3.7 V8 A8 in Akoya Silver
The usual A8 spec plus what I think are the options:
- Comfort heated seats with optional comfort headrests inc. heated steering wheel
- Aluminium pack
- Auto dimming and heated wing mirrors
- Keyless Entry (Kessy)
- Handsfree Bluetooth
- Auto lights and wipers
- Bose sound system
Extras added:
- AFS dynamic Bi-Xenon headlights inc. cornering static light, DRLs converted to LED (new set of LEDs will be fitted just before the sale and new genuine pair of Philips Night Vision xenon bulbs fitted only few months ago along with white MTEC H8s for cornering lights)
- Brand new direct from Audi front S8 bumper
- S8 front grille (de-bagged, aftermarket quattro badge instead)
- S8 Aluminium paddle shifters on the steering wheel
- S8 20" alloy wheels on 265/35 Bridgestone's Potenza + a full size 18" ''fat 5'' as spare + 2x spare coil packs in the boot
- Drilled Zimmermann Sport-Z anti rust discs all round
- Custom and proper handmade (not off the shelf universal type) cat back exhaust by Hayward & Scott inc. upgraded flex pipes near the cats. I am well aware exhaust note may not be everyone's cup of tea hence I will include complete original middle resonator which will tone it down by a fair bit. Really cheap and quick job to do if you take it to guys like Hayward & Scott or Fast Lane Styling in Essex.
- A8 number plate (spare brand new set in the boot with correct spacing, one space instead of two as on the car at the minute, never had any issues with spacing around London tho)
- All callipers has been properly painted all round in gun metal and a little quattro decal has been added so they don't look so plain
- Wide display instrument cluster which is also ready for Adaptive Cruise Control if you wish to retrofit it
- All interior light has been upgraded to LED ones inc. rear number plate
- If matt carbon trim is not your thing then it can be fairly easily removed with no damage whatsoever and bring back to dark gloss wood finish.
- All window switches, mirror switch and FL Start/Stop button has been replaced for the ones with a bit of chrome detail as the standard ones all black are a bit dull (all new from Audi at silly cost, not half worn second hand).
- Remapped by Viezu for better throttle response and a bit more BHPs
- Gently lower via VCDS (not permanent mechanical mod) as A8s are well known for silly by most owners big wheel arch gaps - front -15mm / rear -10mm, that way front and rear looks more even.
- MMI updated to the latest 5570 version inc. 3D maps
Work done (bare in mind I'm known for just putting lots of new bits each time car goes for a service, one reason is just sometimes makes sense to do all the belts, pumps, pulleys while front is off, hence the statement on the beginning about ton of money put in the car):
- Regular servicing
- Rear wheel bearings
- Dif oil
- Twice in last 6 years (most recent one 2016) cam belt change (OEM from Audi) inc. new tensioners and pulleys + water pump + thermostat inc. new alternator belt + new pulleys at the same time (Audi OEM)
- New brake fluid in last couple of years
- New radiator
- New coil packs + spark plugs around 3 years ago
- New coolant reservoir
- Upgraded Gruvenparts aluminium inlet manifold flaps links
- New Bosch S5 battery around 3 years ago
- Oil retaining valve (non return) under the inlet manifold
- Both camshaft chain tensioners (cylinder 1-4 and 5-8) at stupid price, special order from Germany as apparently no one bothers to do change them even if they rattle a bit due to cost so no stock in UK.
- All front upper suspension arms inc. antiroll bar C links twice (OEM by Lemforder), last time in August 2014 inc. laser tracking straight after
- Gearbox serviced twice
- New screen wash pump
- Brake pads all round changed twice
Mechanical condition.
Car has been very well maintained over the years, I'd like to say that for the money you buy a peace of mind considering what has been replaced mainly because I'm the maintenance maniac.
Engine is as smooth as it gets with no knocks, no leaks, just a lovely running well maintained V8.
Gearbox, well, I wish my S8 gearbox was as smooth as this one. I've been driving and been driven in many D3s and I'm proud to say there has been only one gearbox as good as this one. It's just very smooth, no hard shifting, no slips, no hesitation, no jiggering, no cold start issues, no leaks, no holding revs unnecessary. As good as it gets for the age. In Drive just pulls away nicely and in Sport it does what it meant to do, nice sharp ish changes.
Everything else just works like it should considering the mileage @157k, but anyone who knows a bit more than average Joe will tell you that this does not play such a big part on a very well maintained executive cars which are always much better build than an A4 with a 4 cylinder engine for example. Mileage is not a complete myth, but on certain cars not as important. I have honestly driven D3 with much lower miles where engine, gearbox and overall condition had a lot to wish for. I also had other D3 owners admiring how well car is running and how well it's maintained. Anyway, moving on to outside and inside condition.
Outside Condition
Again, please bare in mind this is a 10year old car, BUT for the age car presents it self very well, no dents, no scratches. One of the aluminium roof strips is loosing a bit of paint, but they can be pulled out and resprayed individually. All chrome is in very good and shiny condition apart both rear triangles which has gone a bit milky. Easy to replace tho. Wheels are in good/very good condition. It all obviously depends on our individual standards/ratings. Car has been clayed if not every than every other wash, why not. Regularly waxed. Let me put it this way, an average clean takes me approx 6-7 hours so you get the idea.
Inside Condition
I would honestly say interior is in very good condition. I took same pride in cleaning interior and looking after it as on the outside. At least 4 times a year all leather has been cleaned and two coats of leather balm/conditioner been applied. There is no excessive wear or cracks. Driver seat and arm rest in in good/very good condition where elsewhere condition is very good. Door cards have very minimal wear, only one rear left one has a 10mm cut on the arm rest. Headlining is in very clean state, apart a little make up marks on the passenger’s sun visor.
To be honest, some of the seat belts could be a bit cleaner if you are twisted as me, don't know why I never got round washing them.
Full VDCS scan attached as well.
£6,000 (strictly no offers)
PM if interested
Code:
Monday,07,November,2016,15:00:01:36862
VCDS — Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 16.8.0.3 (x64)
Data version: 20160803 DS255
www.Ross-Tech.com
VIN: WAUZZZ4E46N018372   License Plate: A8 RRU 7/11/2016
Mileage: 253950km-157797mi   Repair Order:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 15 16 17 19 1E 25 34 36 37 38 42 46
          47 4F 52 53 55 56 61 62 67 72 76 77
VIN: WAUZZZ4E46N018372   Mileage: 253950km-157797miles
00-Steering Angle Sensor — Status: OK 0000
01-Engine — Status: Malfunction 0010
02-Auto Trans — Status: OK 0000
03-ABS Brakes — Status: OK 0000
05-Acc/Start Auth. — Status: OK 0000
06-Seat Mem. Pass — Status: Malfunction 0010
07-Control Head — Status: OK 0000
08-Auto HVAC — Status: OK 0000
09-Cent. Elect. — Status: OK 0000
15-Airbags — Status: OK 0000
16-Steering wheel — Status: OK 0000
17-Instruments — Status: OK 0000
19-CAN Gateway — Status: OK 0000
1E-Media Player 2 — Status: OK 0000
25-Immobilizer — Status: OK 0000
34-Level Control — Status: OK 0000
36-Seat Mem. Drvr — Status: OK 0000
37-Navigation — Status: OK 0000
38-Roof Electronics — Status: Malfunction 0010
42-Door Elect, Driver — Status: OK 0000
46-Central Conv. — Status: OK 0000
47-Sound System — Status: OK 0000
4F-Centr. Electr. II — Status: OK 0000
52-Door Elect, Pass. — Status: OK 0000
53-Parking Brake — Status: OK 0000
55-Headlight Range — Status: OK 0000
56-Radio — Status: OK 0000
61-Battery Regul. — Status: OK 0000
62-Door, Rear Left — Status: OK 0000
67-Voice Control — Status: OK 0000
72-Door, Rear Right — Status: OK 0000
76-Park Assist — Status: OK 0000
77-Telephone — Status: OK 0000
Address 01: Engine        Labels: None
   Part No SW: 4E0 910 560 R    HW: 4E0 907 560
   Component: 3.7L V8/5V      G   0010
   Revision: 00000000    Serial number: AUX3Z0ED382579
   Coding: 0011773
   Shop #: WSC 00000 000 08192
   VCID: 306FFF55A3ACADC210-8064
1 Fault Found:
17981 - Left Engine Mount Solenoid Valve (N144)
            P1573 - 004 - Open Circuit
Readiness: 0110 1001
Address 02: Auto Trans        Labels: 09E-927-156.lbl
   Part No SW: 4E1 910 156 D    HW: 09E 927 156 B
   Component: AG6 09E 3,7L5V RdW  0120
   Revision: —H01---    Serial number:        0074483
   Coding: 0000001
   Shop #: WSC 00583 210 82263
   VCID: 24470305E7540162E4-8070
No fault code found.
Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
   Part No SW: 4E0 910 517 B    HW: 4E0 614 517 BC
   Component: ESP 5.7 allrad  H44 0510
   Coding: 0008597
   Shop #: WSC 02313 000 00000
   VCID: 224B051DFD400F5296-8076
Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
   Part No SW: 4E0 910 131     HW: 4E0 909 131 K
   Component:     FBS AUDID3  H10 0190
   Revision: 01904910    Serial number: AUX3Z0ED382579
   Coding: 0412672
   Shop #: WSC 02311 785 00200
   VCID: 58BF67F5EB9C9582B8-800C
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: ELV                 XXXX
Address 06: Seat Mem. Pass        Labels: None
   Part No SW: 4E0 910 760 D    HW: 4E0 959 760 B
   Component: Sitzmemory BFS H02  0010
   Revision: 00000000    Serial number: 5DS 008 795-03
   Coding: 4063328
   Shop #: WSC 00000 785 00200
1 Fault Found:
00003 - Control Module
            014 - Defective - Intermittent
             Freeze Frame:
                    Fault Status: 00101110
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 69
                    Mileage: 199560 km
                    Time Indication: 0
                    Date: 2011.05.12
                    Time: 18:31:44
Address 07: Control Head        Labels: 4E0-910-7xx-07.lbl
   Part No SW: 4E0 910 769 P    HW: 4E0 035 729
   Component: Interfacebox    H43 5570
   Revision: 00000000    Serial number: 343AT067572487
   Coding: 0000002
   VCID: 3979C27170D66C8AA7-806C
   Subsystem 1 - Part No: 4E0 910 609 C
   Component: Bedienteil MMI  H42 0100
   Subsystem 2 - Serial number: 318AH067517024
   Subsystem 3 - Serial number: 7405.01.0600000000218B0028ˇ
   Subsystem 4 - Serial number: 8B0028ˇ
Address 08: Auto HVAC        Labels: None
   Part No SW: 4E0 910 043 B    HW: 4E0 820 043 D
   Component: KLIMAAUTOMAT    016 0400
   Revision: 00000030    Serial number: 00000000084023
   Coding: 0020481
   VCID: 1C373BE5DF2439A25C-8048
Address 09: Cent. Elect.        Labels: 4E0-910-279.lbl
   Part No SW: 4E0 910 279 Q    HW: 4E0 907 279 Q
   Component: ILM Fahrer      H14 0230
   Coding: 0133121
   Shop #: WSC 02313 785 00200
   VCID: 3663C94D41C883F24A-8062
   Subsystem 1 - Part No: 4E2 910 113 B
   Component: Wischer WWS D3  H50 0420
   Coding: 00000037
   Shop #: WSC 02313
   Subsystem 2 - Part No: 4E0 910 557   Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH11 0050
   Coding: 00139548
   Shop #: WSC 02313
Address 15: Airbags        Labels: 4E0-910-655-94.lbl
   Part No SW: 4E0 910 655 D    HW: 4E0 959 655 H
   Component:    Airbag 9.41  H12 3610
   Revision: 91H12360    Serial number: 0037P000CLB-
   Coding: 0431707
   VCID: 275D14099662EA7AC1-8072
   Subsystem 1 - Serial number: 63328RB400D5A41EP
   Subsystem 2 - Serial number: 63428RB400D5C5CE/
   Subsystem 3 - Serial number: 63528RB400D5C62CU
   Subsystem 4 - Serial number: 63628RB400D5C73DY
   Subsystem 5 - Serial number: 63729RB400D323C7N
   Subsystem 6 - Serial number: 63829RB400D32423B
Address 16: Steering wheel        Labels: 4E0-910-549.lbl
   Part No SW: 4E0 910 549 A    HW: 4E0 953 549 B
   Component: J0527               0310
   Revision: 00H01000    Serial number: 90054053530058
   Coding: 0112341
   VCID: 2643190D9168F372FA-8072
   Component: E0221           H07 0090
Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
   Part No SW: 4E0 910 931 E    HW: 4E0 920 931 EX
   Component: KOMBIINSTR. VDO H70 0400
   Revision: D01         Serial number: AUDID3E3000006
   Coding: 0032413
   Shop #: WSC 01240 210 106691
   VCID: 25411E01EC6EF86AF3-8070
Address 19: CAN Gateway        Labels: 4E0-910-468.clb
   Part No SW: 4E0 910 468 B    HW: 4E0 907 468 E
   Component: Gateway         H11 0090
   Revision: 11          Serial number: 20003061028100
   Coding: FCFE7BDC2B7104
Address 1E: Media Player 2        Labels: 4E0-910-111.lbl
   Part No SW: 4E0 910 111 F    HW: 4E0 035 111 A
   Component: CD-Changer      H44 0470
   Revision: 00000000    Serial number: AUZ5ZBF8038653
   Shop #: WSC 00000 000 00000
Address 25: Immobilizer        Labels: 4E0-910-131.lbl
   Coding: 0412672
   Component: ELV                 XXXX
   XXXXXXXXXXX ELV                 XXXX
Address 34: Level Control        Labels: 4E0-910-553.lbl
   Part No SW: 4E0 910 553 H    HW: 4E0 907 553 F
   Component: LUFTFDR.-CDC    H06 4480
   Coding: 0012310
   VCID: 285F17359B7CE502C8-807C
Address 36: Seat Mem. Drvr        Labels: None
   Component: Sitzmemory FS  H02  0010
   Coding: 4063338
Address 37: Navigation        Labels: 4E0-910-88x-37.lbl
   Part No SW: 4E0 910 888 P    HW: 4E0 919 887 D
   Component: MNS ECE         H47 1060
   Revision: 00000000    Serial number: 364AG067521315
   VCID: 3B75D8797AEA5E9AB5-806E
Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
   Part No SW: 4E0 910 135 A    HW: 4E0 907 135 A
   Component: Dachknoten D3   H03 0090
   Serial number: 00000532900056
   Coding: 0035968
   VCID: 1D3136E1C43E30AAAB-8048
3 Faults Found:
02139 - Control Circuit for Left Front Interior Lights
            012 - Electrical Fault in Circuit
             Freeze Frame:
                    Fault Status: 01101100
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 92
                    Mileage: 253952 km
                    Time Indication: 0
                    Date: 2016.11.07
                    Time: 14:53:00
00211 - Control Circuit for Rear Illumination Lights
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 92
                    Mileage: 253952 km
                    Time Indication: 0
                    Date: 2016.11.07
                    Time: 14:53:00
02138 - Control Circuit for Front Right Interior Lights
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 92
                    Mileage: 253952 km
                    Time Indication: 0
                    Date: 2016.11.07
                    Time: 14:53:00
Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
   Part No SW: 4E1 910 802 B    HW: 4E2 959 802 B
   Component: T¸rsteuer.FS BRM003 0100
   Coding: 0028462
   VCID: 204F0F15F34C1D4280-8074
Address 46: Central Conv.        Labels: 4E0-910-289.lbl
   Part No SW: 4E0 910 289 B    HW: 4E0 907 289
   Component: Komfortgeraet   H05 0010
   Revision: 00100005    Serial number:  W040601040009
   Coding: 0004317
   Subsystem 1 - Part No: 4E0 907 719
   Component: Neigungssensor  H04 0020
Address 47: Sound System        Labels: 4E0-910-223.lbl
   Part No SW: 4E0 910 223 R    HW: 4E0 035 223 G
   Component: DSP-High D3     H02 0120
   Revision: PROD_01     Serial number: 00000000200773
   Coding: 0000027
   VCID: 2C57EB258F84C9222C-8078
Address 4F: Centr. Electr. II        Labels: None
   Part No SW: 4E0 910 280 A    HW: 4E0 907 280 A
   Component: ILM Beifahrer   H11 0070
   Revision:             Serial number: 00000000077022
   Coding: 0010101
   VCID: 1E3331EDC9382BB2B2-804A
Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
   Part No SW: 4E1 910 802 B    HW: 4E2 959 801 B
   Component: T¸rsteuer.BF BRM003 0100
   Coding: 0028462
Address 53: Parking Brake        Labels: 4E0-910-801.clb
   Part No SW: 4E0 910 801 C    HW: 4E0 907 801 A
   Component: EPB  A32C0220   H02 0220
   Revision: A32C0220
   Coding: 0000331
   VCID: 1F4D0CE9CE3222BAB9-804A
Address 55: Headlight Range        Labels: 4F0-910-357.lbl
   Part No SW: 4L0 910 357     HW: 4L0 907 357
   Component: AFS 1           H01 0040
   Revision: 00000001    Serial number:
   Coding: 0000018
   VCID: 69D9523140F61C0A17-803C
   Subsystem 1 - Part No: 4F0 941 329 B
   Component: AFS-Modul links H01 0010
   Subsystem 2 - Part No: 4F0 941 329 B
   Component: AFS-Modul rechtsH01 0010
Address 56: Radio        Labels: 4E0-910-541.lbl
   Part No SW: 4E0 910 541 T    HW: 4E0 035 541 L
   Component: TUNER EU/US/RDW H42 0630
   Revision: 00000000    Serial number: 304AG067613490
   Coding: 0000001
   VCID: 3169FA51A8A6A4CA1F-8064
Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
   Part No SW: 4E0 910 181 C    HW: 4E0 915 181 C
   Component: J0644 BEM       H12 0550
   Revision: 00000000    Serial number: 00000000009034
   Shop #: WSC 00583 210 56384
   Subsystem 1 - Part No: 4E0 915 105 A
   Component: von VA0  7777777777
   Coding: 344530393135313035412056413037373737373737373737
   Shop #: WSC 12345 128 00289
Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802 A    HW: 4E0 959 801 C
   Component: T¸rsteuer.HL BRM003 0100
   Coding: 0028462
Address 67: Voice Control        Labels: 4E0-910-75x-67.lbl
   Part No SW: 4E0 910 754 S    HW: 4E0 035 753 A
   Component: SDS 3502 UK     H45 0630
   Revision: 00000000    Serial number: 00000512220101
   Shop #: WSC 12336 024 394758
Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802 A    HW: 4E0 959 802 C
   Component: T¸rsteuer.HR BRM003 0100
   Coding: 0028462
Address 76: Park Assist        Labels: 4E0-910-283.lbl
   Part No SW: 4E0 910 283 C    HW: 4E0 919 283 C
   Component: Parkhilfe 8-Kan H12 0030
   Revision: 00H12000    Serial number: 08720601002460
   Coding: 0201008
   VCID: 23450019E25A065A9D-8076
Address 77: Telephone        Labels: 4E0-910-336.lbl
   Part No SW: 4E0 910 336 M    HW: 4E0 862 335
   Component: Handyvorb2      H00 1130
   Revision: 00000000    Serial number: 00000000000000
   Coding: 0010900
End-------------------------(Elapsed Time: 03:23)------------------------—
ID:	15022   Click image for larger version
ID:	15023   Click image for larger version
ID:	15024   Click image for larger version
ID:	15025   Click image for larger version
ID:	15026   Click image for larger version
ID:	15027   Click image for larger version
ID:	15028   Click image for larger version
ID:	15029   Click image for larger version
ID:	15030   Click image for larger version
ID:	15032   Click image for larger version
ID:	15033   Click image for larger version
ID:	15034   Click image for larger version
ID:	15035   Click image for larger version
ID:	15036   Click image for larger version
ID:	15037   Click image for larger version
ID:	15038   Click image for larger version
ID:	15039   Click image for larger version
ID:	15040   Click image for larger version
ID:	15042   Click image for larger version
ID:	15043   Click image for larger version
ID:	15044   Click image for larger version
ID:	15045   Click image for larger version
ID:	15046   Click image for larger version
Old 15th November 2016, 02:28 PM
If that is not one of the best cared for '8s in the world then I'll eat my hat! The person - not me I'm afraid - who gets this will have a beautifully cared for and maintained car at a bargain price.
GLWTS Marcin - some should be biting your hand off to get this.
P.S Perhaps you should change the description of the spare from "flat 5" to "fat 5" otherwise you might give the wrong impression!
Old 15th November 2016, 05:38 PM
David, thank you very much for your kind words...and how do you even get Fat 5 so wrong, this is hilarious - Flat 5
Thank you for spotting it
I cared for it because I love the car, it served me well and because I don't like changing cars I was going to keep it for much longer so looking after it just made sense.
The only reason it's up for sale because of an accidental S8 purchase so it just makes sense to find a new loving home for her. It's almost like I want to choose the buyer not buyer her if that makes sense.
I've been also advised to put the pictures in the actual ad not as attachments so I did that as well.
And guess what?? Been also told there are crucial pictures missing !!!
A clue you ask?
Something I clean with fine brushes and cotton buds taped to the end of the BBQ sticks to reach the difficult areas
Yes, it is the engine bay! So here are some pics of engine bay and area under the bulkhead which I always hoovered when cleaning the car to keep the drain offs nice and flowing (seen cars being flooded of these areas being let down as you can't see then unless you remove the trims).
ID:	15050   Click image for larger version
ID:	15051   Click image for larger version
ID:	15052   Click image for larger version
ID:	15053   Click image for larger version
ID:	15054   Click image for larger version
ID:	15055   Click image for larger version
ID:	15056   Click image for larger version
Old 15th November 2016, 07:05 PM
If I had 6k Marcin I would snap your arm off. Lovely 8.
Old 15th November 2016, 08:43 PM
RICKY D's Avatar
RICKY D RICKY D is offline
Holy cow that is a clean bay and car - A credit to you sir
Apologies for clogging up your thread, but I can tell this is a beautiful example and deserved a thumbs up. Best of luck with the sale
Old 15th November 2016, 09:13 PM
Sir WIll Sir WIll is offline
Lovely car at a damn decent price
I have no need for it but would love to add it to the collection, same colour as the A2 so it would match
Old 15th November 2016, 09:26 PM
Mike,
I would love that knowing it would go to a serious ''collector'' ...and arm would heal eventually
Ricky,
Thank you mate !!! I just can emotionally cope with oil, dusty and grime engine bays - it's illness and I am well aware of it, problem is that there is no cure for it other than drinking everyday just to stay away from the car
Sir Will,
Thank you Sir And price is just about right to find a real ''collector''/A8 maniac. I'm not joking here, but I wouldn't sell it for lets say £7k to a muppet who I know will just trash it, hand on my heart.
Old 16th November 2016, 08:11 AM
Immaculate and well looked after, good luck with the sale mate
Matt
Old 16th November 2016, 11:01 AM
Is it my OCD but isnt the oil filler cap oriented the "wrong" way??
Old 16th November 2016, 02:56 PM
No its facing the correct way when standing in front of the car
