D3 - Common Faults Quick links to all known common faults and their solutions |
After successfully changing a turbo on 4.0 D3, it was running. Brake fuild warning light came on (car was jacked up at the front). Fluid was added, however message to seek assistance came up on the display. Scanned with Gen Ross tech VDSC:
18259 - Powertrain Data Bus P1851 - 000 - Missing Message from ABS Controller - Intermittent 18255 - Please check DTC Memory of ABS Controller P1847 - 000 - - Intermittent 18262 - Powertrain Data Bus P1854 - 000 - Hardware Malfunction - Intermittent 18289 - Powertrain Data Bus: Missing Message P1881 - 000 - Acceleration Request - Intermittent The rear pads recently showed as low too on the scan. Any advice would be appreciated, should a be checking fuses?. ![]() Steve
2003, A8 D3 4.0 TDI |
Are these faults logged in 01-Engine or 03-ABS?
Matt,
16497 - Intake Air Temp. Sensor (G42) 19591 - Intake Manifold Runner Control 16497 - Intake Air Temp. Sensor (G42) ABS 01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30 I have the full scan, didn't want to just dump it on here. Thanks in advance. Steve
Hi Steve put the full vcds scan up.
Is that all the fault codes. Trev |
[quote=North2007;119011]After successfully changing a turbo on 4.0 D3, it was running. Brake fuild warning light came on (car was jacked up at the front). Fluid was added, however message to seek assistance came up on the display. Scanned with Gen Ross tech VDSC:
18259 - Powertrain Data Bus P1851 - 000 - Missing Message from ABS Controller - Intermittent 18255 - Please check DTC Memory of ABS Controller P1847 - 000 - - Intermittent 18262 - Powertrain Data Bus P1854 - 000 - Hardware Malfunction - Intermittent 18289 - Powertrain Data Bus: Missing Message P1881 - 000 - Acceleration Request - Intermittent Hi steve make sure you have a good car battery and correctly coded to the car,then clear all the codes one by one and see which ones return. cheers trev |
Friday,28,October,2016,10:54:13:12992
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86 VCDS Version: 16.8.3.1 Data version: 20161010 DS267.0 www.Ross-Tech.com VIN: WAUZZZ4E54N002615 License Plate: A8 Mileage: 235700km-146457mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 4E (4E0) Scan: 01 02 03 05 06 07 08 09 11 31 15 16 17 18 19 1E 25 34 36 37 38 42 46 47 4F 52 53 55 56 61 62 72 76 VIN: Mileage: 235700km-146457miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: Malfunction 0010 03-ABS Brakes -- Status: Malfunction 0010 05-Acc/Start Auth. -- Status: OK 0000 06-Seat Mem. Pass -- Status: OK 0000 07-Control Head -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: OK 0000 11-Engine II -- Status: OK 0000 31-Engine other -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: Malfunction 0010 18-Aux. Heat -- Status: Malfunction 0010 19-CAN Gateway -- Status: OK 0000 1E-Media Player 2 -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 34-Level Control -- Status: Malfunction 0010 36-Seat Mem. Drvr -- Status: Malfunction 0010 37-Navigation -- Status: Malfunction 0010 38-Roof Electronics -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: Malfunction 0010 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: OK 0000 61-Battery Regul. -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: Malfunction 0010 ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No SW: 4E0 910 409 C HW: 4E0 907 409 B Component: 4.0L 4V/TDI G000AGMŖ0010 Revision: <> Serial number: AUX3Z0C3114402 Coding: 0010773 Shop #: WSC 02313 785 00200 VCID: 234593F0E2E7385A81-8076 3 Faults Found: 17983 - Right Engine Mount Solenoid Valve (N145) P1575 - 000 - Short to Plus Freeze Frame: RPM: 0 /min Torque: 27.3 Nm Speed: 0.0 km/h Bin. Bits: 0 Bin. Bits: 0 Bin. Bits: 0 Temperature: 10.8°C 19591 - Intake Manifold Runner Control P3135 - 000 - Lower Stop not Reached Freeze Frame: RPM: 0 /min Torque: 27.3 Nm Speed: 0.0 km/h Duty Cycle: 87.9 % Duty Cycle: 20.7 % Duty Cycle: 0.4 % Temperature: 10.8°C 16497 - Intake Air Temp. Sensor (G42) P0113 - 000 - Signal too High Freeze Frame: RPM: 0 /min Torque: 27.3 Nm Speed: 0.0 km/h Voltage: 11.70 V Absolute Pres.: 999.6 mbar Temperature: 9.9°C Temperature: 10.8°C Readiness: 0 0 X X X ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09E-927-156.lbl Part No SW: 4E0 910 156 J HW: 09E 927 156 A Component: AG6 09E 4,0LTDI RdW 0010 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 295981D880CBE20ACB-807C 4 Faults Found: 18259 - Powertrain Data Bus P1851 - 000 - Missing Message from ABS Controller - Intermittent Freeze Frame: RPM: 0 /min RPM: 0 /min RPM: 0 /min (no units): 30.0 (no units): 25.0 Temperature: 20.0°C T.B. Angle: 0.0° Voltage: 12.72 V 18255 - Please check DTC Memory of ABS Controller P1847 - 000 - - Intermittent Freeze Frame: RPM: 0 /min RPM: 0 /min RPM: 0 /min (no units): 30.0 (no units): 25.0 Temperature: 20.0°C T.B. Angle: 0.0° Voltage: 12.72 V 18262 - Powertrain Data Bus P1854 - 000 - Hardware Malfunction - Intermittent Freeze Frame: RPM: 0 /min RPM: 0 /min RPM: 0 /min (no units): 30.0 (no units): 25.0 Temperature: 20.0°C T.B. Angle: 0.0° Voltage: 12.72 V 18289 - Powertrain Data Bus: Missing Message P1881 - 000 - Acceleration Request - Intermittent Freeze Frame: RPM: 0 /min RPM: 0 /min RPM: 0 /min (no units): 30.0 (no units): 25.0 Temperature: 20.0°C T.B. Angle: 0.0° Voltage: 12.72 V ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4E0-910-517.lbl Part No SW: 4E0 910 517 A HW: 4E0 614 517 A Component: ESP 5.7 allrad H29 0420 Coding: 0008557 Shop #: WSC 02313 000 00000 VCID: 214999F8F8FB2A4A93-8074 1 Fault Found: 01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30 000 - - ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 Component: FBS AUDID3 H02 0120 Revision: 01203602 Serial number: AUX3Z0C3114402 Coding: 0264192 Shop #: WSC 23123 823 56694 VCID: 58BFF41CEB21AB82A4-800C Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX No fault code found. ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass Labels: None Part No SW: 4E0 910 760 C HW: 4E0 959 760 Component: Sitzmemory BFS H06 0060 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063328 Shop #: WSC 00000 785 00200 VCID: 234593F0E2E7385A81-8076 No fault code found. ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4E0-910-7xx-07.lbl Part No SW: 4E0 910 729 G HW: 4E0 035 729 Component: Interfacebox H43 0770 Revision: 00000000 Serial number: 343EE037514412 Coding: 0000002 Shop #: WSC 00720 210 02493 VCID: 2C5778CC8F39F72230-8078 Subsystem 1 - Part No: 4E0 910 609 Component: Bedienteil MMI H41 0010 Subsystem 2 - Serial number: 322AF037502693 Subsystem 3 - Serial number: ˙˙17.01.03˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙ Subsystem 4 - Serial number: ˙˙˙˙˙˙˙ No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 4E0 910 043 HW: 4E0 820 043 A Component: KLIMAAUTOMAT 015 0240 Revision: 00000017 Serial number: 00000000016781 Coding: 0022531 Shop #: WSC 00720 210 02493 VCID: 5ABBEE14952DB99292-800E 9 Faults Found: 00716 - Air recirculation Flap Positioning Motor (V113) 003 - Mechanical Failure Freeze Frame: Fault Status: 01100011 Fault Priority: 3 Fault Frequency: 53 Reset counter: 144 Mileage: 235151 km Time Indication: 0 Date: 2016.10.14 Time: 20:14:25 Freeze Frame: Voltage: 11.60 V Temperature: 14.0°C (no units): 201.0 (no units): 86.0 Temperature: -80.0°C 01858 - Air Outlet Sensor; Right Center (G348) 007 - Short to Ground - Intermittent Freeze Frame: Fault Status: 00100111 Fault Priority: 3 Fault Frequency: 64 Reset counter: 183 Mileage: 235153 km Time Indication: 0 Date: 2016.10.15 Time: 10:41:35 00711 - Left Footwell Flap Positioning Motor (V108) 003 - Mechanical Failure - Intermittent Freeze Frame: Fault Status: 00100011 Fault Priority: 3 Fault Frequency: 29 Reset counter: 183 Mileage: 235153 km Time Indication: 0 Date: 2016.10.15 Time: 10:41:42 Freeze Frame: Voltage: 13.70 V Temperature: 15.0°C (no units): 62.0 (no units): 89.0 Temperature: -89.0°C 00819 - High Pressure Sensor (G65) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 183 Mileage: 235708 km Time Indication: 0 Date: 2003.02.28 Time: 01:55:33 00729 - Potentiometer in Positioning Motor for Right-Hand Central Vent (G137) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 3 Fault Frequency: 47 Reset counter: 183 Mileage: 235214 km Time Indication: 0 Date: 2016.10.16 Time: 10:54:02 Freeze Frame: Voltage: 13.90 V (no units): 210.0 (no units): 255.0 00732 - Potentiometer in Positioning Motor for Right-Hand Footwell Flap (G140) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 3 Fault Frequency: 3 Reset counter: 182 Mileage: 235283 km Time Indication: 0 Date: 2016.10.19 Time: 18:53:15 Freeze Frame: Voltage: 14.00 V (no units): 116.0 (no units): 255.0 00600 - Potentiometer On Positioning Motor for Temperature Flap (G92) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 3 Fault Frequency: 2 Reset counter: 178 Mileage: 235284 km Time Indication: 0 Date: 2016.10.19 Time: 18:54:09 Freeze Frame: Voltage: 14.10 V (no units): 102.0 (no units): 255.0 01857 - Air Outlet Sensor; Middle Left (G347) 007 - Short to Ground - Intermittent Freeze Frame: Fault Status: 00100111 Fault Priority: 3 Fault Frequency: 7 Reset counter: 183 Mileage: 235689 km Time Indication: 0 Date: 2016.10.21 Time: 21:26:03 01206 - Signal for Duration of Ignition Off Time 014 - Defective Freeze Frame: Fault Status: 00100111 Fault Priority: 3 Fault Frequency: 7 Reset counter: 183 Mileage: 235689 km Time Indication: 0 Date: 2016.10.21 Time: 21:26:03 ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4E0-910-279.lbl Part No SW: 4E0 910 279 E HW: 4E0 907 279 E Component: ILM Fahrer H11 0100 Coding: 0010001 Shop #: WSC 02311 785 00200 VCID: 2A5B7ED485CDE912C2-807E Subsystem 1 - Part No: 4E2 910 113 Component: Wischer WWS D3 H30 0320 Coding: 00000030 Shop #: WSC 02311 No fault code found. ------------------------------------------------------------------------------- Address 11: Engine II Labels: Redir Fail! Part No SW: 4E0 910 409 C HW: 4E0 907 409 B Component: 4.0L 4V/TDI G000AGSŖ0010 Revision: <> Serial number: AUX3Z0C3114402 Coding: 0010773 Shop #: WSC 02313 785 00200 VCID: 234593F0E2E7385A81-8076 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4E0-910-655-84.lbl Part No SW: 4E0 910 655 HW: 4E0 959 655 Component: Airbag 8.4E+ H08 0940 Coding: 0431707 Shop #: WSC 02313 785 00200 VCID: 63C5D3F0A267785AC1-8036 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4E0-910-549.lbl Part No SW: 4E0 910 549 HW: 4E0 953 549 Component: Lenksäulenmodul H09 0030 Coding: 0112141 Shop #: WSC 02311 785 00200 VCID: 65C1CDE8AC53066A2F-8030 Subsystem 1 - Part No: XXXXXXXXXXX Component: Lenkradmodul H02 0050 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4E0-910-xxx-17.lbl Part No SW: 4E0 910 900 HW: 4E0 920 950 A Component: KOMBIINSTR. VDO H42 0060 Revision: D07 Serial number: AUDID3C3000061 Coding: 0000403 Shop #: WSC 50741 143 61874 VCID: 5CB7E80C9F1947A280-8008 1 Fault Found: 00779 - Outside Air Temp Sensor (G17) 010 - Open or Short to Plus Freeze Frame: Fault Status: 00000011 Fault Priority: 7 Fault Frequency: 4 Reset counter: 144 Mileage: 235708 km Time Indication: 0 Date: 2016.10.22 Time: 18:49:45 ------------------------------------------------------------------------------- Address 18: Aux. Heat Labels: None Part No SW: 4E0 910 105 HW: 4E0 815 069 C Component: Heizgeraet H06 0280 Revision: 0000000E Serial number: 00000009001484 Shop #: WSC 00000 000 00000 VCID: 59B9F118902BB28A9B-800C 1 Fault Found: 02072 - Control Module for Energy Management (J644) 004 - No Signal/Communication ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 4E0-910-468.clb Part No SW: 4E0 910 468 HW: 4E0 907 468 A Component: Gateway H07 0070 Revision: 07 Serial number: 160030480513E9 Coding: FCFEFBDE2B2104 Shop #: WSC 00720 210 02493 VCID: 65C1CDE8AC53066A2F-8030 No fault code found. ------------------------------------------------------------------------------- Address 1E: Media Player 2 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 111 C HW: 4E0 035 111 Component: CD-Changer H43 0340 Revision: 00000000 Serial number: AUZ5ZBD4013149 Shop #: WSC 00000 000 00000 VCID: 1939B118D0AB728A5B-804C No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 Component: FBS AUDID3 H02 0120 Revision: 01203602 Serial number: AUX3Z0C3114402 Coding: 0264192 Shop #: WSC 23123 823 56694 VCID: 58BFF41CEB21AB82A4-800C Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX XXXXXXXXXXX ELV XXXX No fault code found. ------------------------------------------------------------------------------- Address 34: Level Control Labels: 4E0-910-553.lbl Part No SW: 4E0 910 553 F HW: 4E0 907 553 E Component: LUFTFDR.-CDC H05 6260 Coding: 0000001 Shop #: WSC 12345 210 01865 VCID: 26438AE491D5CD72E6-8072 1 Fault Found: 00778 - Steering Angle Sensor (G85) 008 - Implausible Signal Freeze Frame: Fault Status: 11101000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 144 Mileage: 235708 km Time Indication: 0 Date: 2003.02.27 Time: 00:30:16 ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No SW: 4E0 910 760 D HW: 4E0 959 760 B Component: Sitzmemory FS H02 0010 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063330 Shop #: WSC 00000 000 00000 VCID: 244790ECE7E93F62F8-8070 2 Faults Found: 02095 - Component Protection Active 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 144 Mileage: 64376 km Time Indication: 0 Date: 2006.07.27 Time: 13:15:35 02084 - Component Protection 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01100101 Fault Priority: 4 Fault Frequency: 1 Reset counter: 144 Mileage: 0 km Time Indication: 0 Date: 2006.01.01 Time: 00:00:00 ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 888 P HW: 4E0 919 887 C Component: MNS ECE H43 1060 Revision: 00000000 Serial number: 353J/047581796 Shop #: WSC 02313 785 00200 VCID: 3B754B907A57609AA9-806E 2 Faults Found: 00862 - Antenna for GPS Navigation (R50/R52) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 144 Mileage: 235708 km Time Indication: 0 Date: 2003.02.27 Time: 00:10:37 02927 - DVD Read Error 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 6 Fault Frequency: 1 Reset counter: 144 Mileage: 235708 km Time Indication: 0 Date: 2003.02.27 Time: 00:10:28 Freeze Frame: Hex Value: 0x3E5D Hex Value: 0x5774 Hex Value: 0x0901 Hex Value: 0x0409 ------------------------------------------------------------------------------- Address 38: Roof Electronics Labels: 4E0-910-135.lbl Part No SW: 4E0 910 135 A HW: 4E0 907 135 A Component: Dachknoten D3 H01 0090 Serial number: 00000411100066 Coding: 0035840 Shop #: WSC 00720 210 02493 VCID: 1D31A508C4830EAAB7-8048 2 Faults Found: 02139 - Control Circuit for Left Front Interior Lights 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 0 Fault Frequency: 1 Reset counter: 144 Mileage: 235708 km Time Indication: 0 Date: 2003.02.27 Time: 00:10:00 02138 - Control Circuit for Front Right Interior Lights 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 0 Fault Frequency: 1 Reset counter: 144 Mileage: 235708 km Time Indication: 0 Date: 2003.02.27 Time: 00:10:00 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl Part No SW: 4E1 910 802 HW: 4E2 959 802 Component: Türsteuer.FS BRM004 0080 Coding: 0028450 Shop #: WSC 02311 785 00200 VCID: 5EB3E204890555B2EE-800A No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4E0-910-289.lbl Part No SW: 4E0 910 289 A HW: 4E0 907 289 Component: Komfortgeraet H03 0030 Revision: 00300003 Serial number: W040305140015 Coding: 0000217 Shop #: WSC 02311 785 00200 VCID: 275D87E096DFD47ADD-8072 Subsystem 1 - Part No: 4E0 907 719 Component: Neigungssensor H02 0020 2 Faults Found: 00985 - Right Tail Light (M2) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 254 Reset counter: 144 Mileage: 224720 km Time Indication: 0 Date: 2015.06.22 Time: 17:15:05 01134 - Alarm Horn (H12) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 254 Reset counter: 144 Mileage: 184703 km Time Indication: 0 Date: 2012.04.02 Time: 15:52:17 ------------------------------------------------------------------------------- Address 47: Sound System Labels: 4E0-910-223.lbl Part No SW: 4E0 910 223 G HW: 4E0 035 223 A Component: DSP-Amp.-High H13 0360 Revision: PROD_01 Serial number: 00000000047667 Coding: 0000011 Shop #: WSC 02313 785 00200 VCID: 214999F8F8FB2A4A93-8074 No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: None Part No SW: 4E0 910 280 HW: 4E0 907 280 A Component: ILM Beifahrer H06 0060 Revision: Serial number: 00000000014231 Coding: 0010101 Shop #: WSC 02311 785 00200 VCID: 5DB1E50884034EAAF7-8008 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl Part No SW: 4E1 910 802 HW: 4E2 959 801 Component: Türsteuer.BF BRM004 0080 Coding: 0028450 Shop #: WSC 02311 785 00200 VCID: 5EB3E204890555B2EE-800A No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4E0-910-801.clb Part No SW: 4E0 910 801 A HW: 4E0 907 801 Component: EPB AV1C1010 H01 1010 Revision: AV1C1010 Coding: 0000431 Shop #: WSC 00720 210 02493 VCID: 1D31A508C4830EAAB7-8048 1 Fault Found: 02596 - Rear Brake Pads Worn 008 - Implausible Signal Freeze Frame: Fault Status: 01111000 Fault Priority: 6 Fault Frequency: 1 Reset counter: 144 Time Indication: 0 Freeze Frame: Voltage: 11.80 V Count: 61 ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 4E0-910-357.lbl Part No SW: 4E0 910 357 HW: 4E0 907 357 Component: Pre-AFS H01 0030 Revision: 00000001 Serial number: Coding: 0000002 Shop #: WSC 02311 785 00200 VCID: 62CBD6F4BD7D7152CA-8036 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 C HW: 4E0 035 541 Component: TUNER EU/US/RDW H41 0290 Revision: 00000000 Serial number: 304EO037524595 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 204F9CFCF3F123429C-8074 No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4E0-910-181.lbl Part No SW: 4E0 910 181 B HW: 4E0 915 181 Component: ENERGIEMANAGER H02 0240 Revision: 00000000 Serial number: 00000000007380 Shop #: WSC 00720 210 02493 VCID: 1F4D9F00CE8F1CBAA5-804A Subsystem 1 - Part No: 000 915 105 AK Component: von VA0 1403240272 Coding: 303030393135313035414B56413031343033323430323732 Shop #: WSC 00720 210 02493 3 Faults Found: 02272 - Quiescent Current Stage 1 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 3 Reset counter: 255 Mileage: 235151 km Time Indication: 0 Date: 2016.10.14 Time: 20:18:07 02273 - Quiescent Current Stage 2 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 255 Mileage: 235708 km Time Indication: 0 Date: 2003.02.28 Time: 02:10:50 02276 - Quiescent Current Stage 5 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 255 Mileage: 235708 km Time Indication: 0 Date: 2003.02.28 Time: 02:11:00 ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 HW: 4E0 959 801 A Component: Türsteuer.HL BRM004 0080 Coding: 0028450 Shop #: WSC 02311 785 00200 VCID: 5DB1E50884034EAAF7-8008 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 HW: 4E0 959 802 A Component: Türsteuer.HR BRM004 0080 Coding: 0028450 Shop #: WSC 02313 785 00200 VCID: 5DB1E50884034EAAF7-8008 No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4E0-910-283.lbl Part No SW: 4E0 910 283 HW: 4E0 919 283 A Component: Parkhilfe 8-Kan H07 0030 Coding: 0001008 Shop #: WSC 02313 785 00200 VCID: 60CFDCFCB3716342DC-8034 2 Faults Found: 02069 - Front Parking Aid Sensors 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 3 Fault Frequency: 2 Reset counter: 184 Mileage: 235708 km Time Indication: 0 Date: 2003.02.27 Time: 00:46:22 01316 - ABS Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 14 Reset counter: 184 Mileage: 235708 km Time Indication: 0 Date: 2003.02.28 Time: 02:14:37 End-------------------------(Elapsed Time: 03:40)--------------------------
Trev, A new battery was fitted a few weeks, however not coded. I'll look at this tonight and code. Thanks Steve
yea I think must of them are down to a flat battery.
Yes like said ,clear down all codes , has the subframe or steering rack been removed to do turbo , is there a electrical connector on the steering rack head ?
Is the steering wheel straight ahead when driving down a straight road It may need steering wheel centralisation adaption Go into abs or steering angle sensor ,under adaptations and run through centralisation procedure When wheel straight ahead angle should show 0 degrees , turn wheel one way it should count up , turn it the other it will count up but in a minus value . Your code for steering angle is like something is diss connected . A few things to go at ... |
Lee, all codes cleared. Subframe and rack remained in place, only cooling and alternator removed. New battery doesn't seem to have a code, I'll return for a batttery with a BEM code, before coding. That's for your advice.
