I'm currently using a USB cable with a 16gb stick in my AMI and it works fine, no issues really but I'm keen to use either my iPhone or iPod.
Mainly because of Amazon Music or at least the theory I have of Amazon Music. My Theory is that I'll be able to play the downloaded songs from Amazon music without having to unplug the device. I've recently bought 3 genuine Audi cables, 2 for the iPod (old 30pin connection) and one for lighting connection(4F0051510AC). I bought two cables for the old 30 pin as apparently there are two different types, 1 for 2g and 1 for 3g. One cable didn't work and the other did work for about 5mins, then stopped working and never worked again. I've tried this on other AMI and other A8s but it didn't work. So I have up. Work gave me a new iPhone and I bought the lighting cable (4F0051510AC) and tested that. That didn't work. Is anyone using an apple product with their AMI, how is it going?
There was a firmware update for the AMI that sorted some Apple compatibilty, especially with the newer IOS versions. Problem is AMI has not been updated for a few years, so may not be compatible with the latest iOS version.
http://www.vwaudiforum.co.uk/forum/s...nline-DOWNLOAD
I went through a number of them that didn't work, then finally found the one that did. For the life of me, I can't remember what colour the collar was on that one!
At the moment, I'm using the 30-pin AMI cable and an Apple 30-pin to Lightning converter. I'm convinced it doesn't sound as good as the AMI lightning cable that did work, but it seemed a wasteful amount to spend at the time, so i returned it in favour of the cheaper option (which is distinctly unlike me!) |
The final firmware version - 0850 - originally came on the 5150 MMI CD and was on the 5570 one too. A VCDS scan for an AMI at the final level should like like this:- Address xx: Media Player x (R199) Labels: 4E0-035-785.lbl Part No SW: 4E0 035 785 F HW: 4E0 035 785 C Component: SG ext.Player H20 0850 Revision: 00000000 Coding: 010000 xx and x vary depending on which optical bus interface the AMI is connected. Without access to VCDS you can check the SW part number and the level number - 0850 - using the 'red screen' in the MMI If you're not at SW 4E0 035 785F, which is the part number for the 0850 firmware, you need to update the AMI. For cars at 5570, this is not normally a problem if the AMIs been in the car a long time but a retro fitted AMI may not be at the correct level. Regards - Julian
Audi A8 3.0TDi MY2016 in Nautilus Silver. Audi A8 3.0TDI MY2005 in Midnight Blue. Gone since 2018, after 10 years! |
thanks for the link Manny.
I've got 2 different 30pin cables, 2 usb cables and 1 lighting cable. Only the USB cables work. I'm not sure what version my AMI is. I bought it from Audi direct about a year ago. What's the chances of that having the latest version? I'll try Manny's link and see if I can update via USB. I don't have a CD player any more. Any ideas if the USB don't work?
The 'Red Menu' is a useful general diagnostic for the MMI and its attached devices and shows ALL the connected units with their MMI BUS ID and Hardware [HW] and Software [SW] versions (with dates).
With the MMI started, you need to press and hold 'Setup' and while continuing to hold 'Setup' press 'Return' as well. After about 5 secs, the Red menu appears and list all the car's devices. Scroll down to the AMI [see 0 Config-b]and press the big button and you'll get a screen of info [see 8 AMI]. Julian
i'll do that tomorrow.
