Old 18th May 2017, 07:33 PM
Default Wanted - D2 S8 front upright for Brembos
Hi all, Does anyone have a driver's side D2 S8 front alloy upright for Brembos please? I just discovered the annoying suspension knock I've been trying to identify is a loose upper arm, and when I tightened the pinch bolt a bit more the upright cracked I think the hole must have distorted like Sergey's did.
Part number is 4D0407254A. There are none on ebay UK, Germany or US, or allegro.pl. I can't even pinch one from the FE as that has the steel uprights.
With the cat rattling as well, its not been a very good D2 week so far
Old 18th May 2017, 08:09 PM
Sorry to hear that MJ Are you going to get that car to the meet?
Sounds painful for Sergei too (oo-err missus!)
Old 18th May 2017, 08:20 PM
Can't say at the moment. Depends whether I can either find another upright or repair the broken one.
Old 18th May 2017, 08:55 PM
RICKY D's Avatar
RICKY D RICKY D is offline
Good luck trying to find one. I had issues with both of mine last year. One cracked like yours which I had welded up, and the other one went oval shaped which had a sleeve machined to fit.
They've been fine in the 9 or so months since fitting but I may switch to steel ones in the future.
Old 19th May 2017, 06:55 AM
The sleeve idea worked then? Thats handy to know. Was the upright machined over-size and then the sleeve pressed in, or something along those lines?
I guess I may end up doing something similar. For now I'm probably going to have to borrow both the steel uprights from the FE, assuming they will come apart
Old 19th May 2017, 07:30 AM
RICKY D's Avatar
Yes, the sleeve idea has been fine so far....I'm always wary though if I hit a big bump in the road.
The engineering company basically did what mentioned above. I'm not sure if they used aluminium or steel, but the old boy who did it was confident it would not give any issues.
If you go the steel upright root do you need to change hubs, bearings and sensors?
Old 19th May 2017, 08:08 AM
RICKY D's Avatar
SyncroS8 has some advertised on here
http://forum.a8parts.co.uk/showthrea...375#post126375
Old 19th May 2017, 10:58 AM
Oh I'd forgotten about that one thanks!
Old 19th May 2017, 01:56 PM
Spoken to SyncroS8 and secured the pair of uprights, but I can't get them until after the meet so it looks like my S8 will be wearing FE steel uprights for the trip North and getting alloy ones back on when we get home
Good job I have my own workshop really otherwise that'd be an expensive exercise... For a while it almost looked easier to put my good engine in the FE and come in that, but the grey car has a better stereo
Old 19th May 2017, 06:29 PM
Nonchalant.. or what!
