Old 23rd June 2017, 07:47 PM
karlcossy karlcossy is offline
Default fitting hybrid tv tuner
just got one from ebay item number 122558846168 unplugged my analog unit plugged this in everything works but there is no tv listed on mmi
am I missing something please help
Old 23rd June 2017, 10:12 PM
What do you mean by "everything works"?
Can you see it on the optical bus? Is the bus loop complete? Is it coded properly? Is it a MOST BUS one?
Julian
Audi A8 3.0TDi MY2016 in Nautilus Silver.
Audi A8 3.0TDI MY2005 in Midnight Blue. Gone since 2018, after 10 years!
Old 23rd June 2017, 11:30 PM
I mean other items work radio cd etc I can see it on vcds but its not coming up on selection list on mmi
Old 24th June 2017, 02:08 AM
I would imagine the new unit would need different coding in the relevant section so that the car knows you have a tv unit fitted
Old 24th June 2017, 09:38 AM
But he says it's replacing an analogue unit so it should already be defined to the car [in the Gateway List, for instance].
Karlcossy;
1) can we see the VCDS output from VCDS Autoscan? [So we can see the part numbers, levels and coding].
2) Can we see the results of an optical bus test? [To see it's on the bus].
Julian
Old 25th June 2017, 11:22 PM
I can take a pic on vcds screen for you where do I click on here to upload pic?
Old 26th June 2017, 11:21 AM
Analog to Digital swap out shouldn't need any coding - but - if you're on an older version of the MMI firmware, it might not recognise the device, and hence TV has gone from your list.....
Old 26th June 2017, 05:59 PM
The simplest thing is not to take a camera picture but to upload the text file that is created by the scan. WHen you run a VCDS AUtoscan, it puts the output in a file in the Ross Tech 'Scans' folder. Just attach the text file to a reply.
[After you type you reply, scroll down and click 'Manage attachments'. Thyen select the text file on your PC and click upload].
Julian
Old 26th June 2017, 06:06 PM
IT; I don't think any MMI level added support for the Hybrid TV; it was a plug replacement for the analog TV. And as you said, it shouldn't need recoding [although it might if it came from a non-UK car or an A6].
I suspect it's some sort of connection issue, which is why I'd like to see an optical scan of the MOST bus and an AUtoscan [which will tell me the MMI level - Control Head FW level - and the TV part number details ]...
Julian
Old 27th June 2017, 10:25 AM
If there were a connection issue, the whole MOST bus would go dead and he would have no MMI at all......
The fact that the MMI is up, but showing no TV suggests that the TV tuner is in the loop and alive enough to repeat data on the ring.....
