Old 4th March 2018, 08:42 AM
Takemetothepub Takemetothepub is offline
Default Front Passenger wheel camber well out!
Walked past the A8 yesterday and the front passenger wheel camber looks massively wrong!
The Wheel is leaning so that the top of the wheel leans in to into the body and the bottom of the wheel is sticking out!
The bottom of the tyre sticks out about an inch more than the drivers side!
Thinking it's maybe the upper control arms?
Anyone had this before?
2005 6.0 W12 Quattro SWB - Need an OPEC membership to run it!
Old 4th March 2018, 09:10 AM
Are you looking at it on level ground on a flat surface and with the wheels turned straight ahead? If one side looks different to the other then, then it needs investigation but if it drives ok and you're getting no air suspension warning lights then I suspect it's fine
