Good evening,
Hopefully I can get some guidance on a retrofit I've just done on my 2006 A8. I've removed the existing faulty Motorola 4e086233c fixed phone module and fitted a 4E0 862 335 (HW13) Bluetooth unit I got from an Audi parts specialist. The required wires from the Motorola plug were removed and fitted into the 52 pin plug that came with the Bluetooth unit. 33 Diagnostics - Pin 14. 42 Mic + - Pin 11. 41 Mic gnd - Pin 12. 15 Gnd - Pin 10. 16 Gnd - Pin 2. 35 +12v - Pin 1. Once this was done I plugged the 52 pin plug in the Bluetooth unit along with the MOST fiber optic plug and the Bluetooth aerial. I then replaced the fuse and switched the ignition on. MMI Screen popped up for a few seconds and then went blank. Checked feed on pins 1 and 2 of Bluetooth unit which showed a healthly 12.7 volts. Removed MOST plug and installed Audi bypass link and everything fired up fine which indicated a problem with the newly fitted Bluetooth module. Refitted MOST plug into unit and switched ignition on, again screen pops up for a few seconds and then blank. Fired up VCDS and tried opening up module 77 telephone but no connection. Then ran optic test which showed electrical and optical error with 77 - Telephone module. Am I missing something simple or does it indeed look like the unit purchased from the specialist is defective? When I enquired before purchasing they stated it had been tested and also comes with a 2 week warranty. MMI is software version 5570 and everything work fine when the Bluetooth unit is bypassed via a MOST link. Bluetooth unit is software version 4E0 910 336F Thanks in advance for any guidance/help. Regards Ben. |
Welcome along to the forum -
It would be good if you could introduce yourself and you car in the relevant section - the folks here like to see pictures of the cars too. I'm by no means an expert, but have you altered the coding using VAGcom to code out the armrest handset and to code in the bluetooth module so that the car knows it has one? Might be what it is. . . . ![]()
Hi Bendy,
Looks ike you used the correct pinouts as they are the same as this thread... http://forum.a8parts.co.uk/showthread.php?t=908 which a few of us used, including me (but it was years ago) If you are sure the electric pins were swapped to the correct posisitions, then I would say it's a faulty unit as it is quite a simple retrofit, the hardest thing is getting under the carpet for the physical swap out. It might be worth checking pins 1 & 2 for 12V as if any unit on the MOST bus doesn't power up, the whole MOST bus is down (no bypass feature). Last edited by snapdragon; 21st March 2018 at 07:54 AM. |
Thanks for the welcome. I have only just got the car so will get some pictures and an introduction posted soon.
Took the carpet and the front passenger seat out so no real problems with access. Pin1 and 2 has a healthy 12.8v on it when the ignition is on and the MOST bus is fine if I unplug it from the Bluetooth module and plug in a MOST loop, with the radio, cd, satnav, DAB, Bose amp all working correctly. When I unplug the loop and plug the MOST bus back into the Bluetooth unit the system reboots but the screen just shows Audi MMI intro and then goes black. If you reset the MMI (using Tel, middle, top right buttons together) again it starts up with the intro screen and then just black, indicating the MOST bus in incomplete. Got a response from the seller saying it was definitely working but that he would take it back if I couldn't get it to work. The only other thing I can think of is that maybe the MOST diagnostic wire is defective, pin 14. Is there any simple way of testing this wire (voltage, frequency etc) ? many thanks Ben |
With the unit plugged in and powered up but with the MOST unplugged, does the unit emit a red light from the MOST socket?
Tested the unit with a lab 12v power supply.
12.3v to pin 1 and ground to Pin 2. Turned the supply on but nothing emitting from the MOST socket. It also wasn't emitting anything when it was plugged into the car yesterday with the MOST cable removed. I'm going to return it for a refund I think. Regards Ben |
Just to add, when you get a working unit in you'll next have to get component protection removed for it to fully work.
Matt 2004 A8 3.7q, 1998 A4 2.8q, 1994 Coupe 2.8q SORN, Last edited by mattylondon; 21st March 2018 at 06:35 PM. |
Bose amp does, so does CD changer, but phone / TV / Radio / AMI are CP free I believe.
For parts enquiries and Forum User Administration please contact customer services directly, not me ![]() The Daily Town Car - 2023 Tesla Model Y Performance. Black with Black. Giant ipad screen, huge sunroof, 4 wheel drive, Tow bar, lots of ooomph and made in China, so actually built properly unlike the Californian ones. The Family Wagon - 2018 Tesla Model X. Black, 7 Seats, Towbar, Homelink, Enhanced Auto pilot with Summon and self park, Heated front seats, CCS Charger upgrade, MCU2 Upgrade, Falconwing Doors, Self opening / closing doors, Netflix, Spotify, toys, Air suspension, alcantara roof + lots of other stuff...... The 17 year old Driver Wagon 2015 Skoda Citigo Monte Carlo. Alloys, Power steering, Aircon, Leccy windows, Sat Nav, bluetooth, central locking, cup holders, 59 whole bhp. Million times better than my first car. Well jealous..... The First 20 Audis: 2001 D2 4.2 QS Silver, 1997 D2 S8 Silver, 1999 D2 4.2 Silver, 2002 D2 S8 Dolphin Grey, 2003 C5 RS6 Blue, 1998 D2 S8 Black, 2000 D2 4.2 QS/S8 Ming Blue, 2003 D3 4.2 Ming Blue, 2005 B7 S4 Blue, 2006 D3 3.0 Tdi Black, 1999 D2 4.2 Silver, 2003 D3 4.2 LPG Crystal Blue, 2000 D2 S8 Silver, 2007 3.0 Tdi Q7 Black, 2009 B8 S4 Black, 1998 D2 S8 Agate Grey, 2006 D3 4.2 Tdi Blue, 2006 D3 S8, 2007 Q7 3.0 Tdi, 2006 C6 S6, The Second 20 Audis: 2011 A7 Sline, 2001 A2 1.4 Tdi Black, 2002 A2 1.4 Tdi Silver, 2006 A8 4.2 Tdi Blue, 2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black ![]() 2010 A8 D4 4.2 Silver, 2006 C6 A6 2.7 Tdi Quattro, 2000 D2 4.2 QS/S8 Ming Blue (again), 2008 Q7 4.2 Black, 2009 C6 RS6 Saloon Daytona Grey, 2001 Fully Loaded A2 Tdi, 2006 Avant S6 Black, 2007 VW Caravelle Exec Black (almost an Audi) 2009 TT Roadster Daytona, 2015 Q7 4.2 tdi lava grey, 2002 GmbH D2 demonstrator, 2006 D3 A8 LWB 4.2 Tdi Black Most Recent Audis: 2001 A2 1.4 Tdi Black, 2007 4.2 FSi Q7 ABT Blue, 2016 S5 Coupe Launch model, 2004 S4 B6 Cabriolet, 2016 Q7 Sline White, 2006 Q7 4.2 FSi Black, 2012 Q7 Sline+ 4.2Tdi White, 2008 Blue Audi S8 Everything Else 1989 Subaru Justy, 1986 Vauxhall Cartlton 2.0 GL, 1985 Vauxhall Carlton 2.2 CDi, 1987 Ford Sierra XR4x4, 1983 Vauxhall Senator, 1985 Vauxhall Senator 3.0i, 1997 Polo Saloon, 1997 Peugeot 306 1.9 TDi, Ford Sierra Sapphire 2000E, 1990 Subaru Justy, 2000 Subaru Impreza, 2000 Subaru Impreza RB5, 1993 Range Rover LSE, 2005 VW Bora, 2003 Skoda Superb, 2003 VW Passat V6 4 Motion, 1996 Peugeot 106, 2000 Range Rover 4.0, 2019 Tesla Model 3 Performance |
Good to know there's no CP on that module
