Old 11th May 2018, 08:04 PM
Chip2786 Chip2786 is offline
Default Possible stupid MOST question
My car came specced with a DTV Tuner but at some point it got removed, I’ve ordered a replacement unit which arrived today but I can’t find a spare MOST Optical cable in the left side of the boot. I noticed that the cables are ‘twin core’ so I presume one is the optical ‘in’ to the Radio tuner and the other is the loop back to the head unit.
I found (in left side of the boot) another MOST plug with a bare end, do I need to remove one of the optical cables from the Radio tuner and fit it into the random plug I found then loop that back to the head unit?
If so, does it matter which way round they go?
Jobs done so far;
Fitted an RS Steering Wheel, Fitted 15mm wheel spacers, Lowered 10mm with VCDS, Reinstalled factory DVB, Unlocked VIM, Updated MMI to 5570, Fixed Factory Bluetooth Phone, Fitted heated fan-spray washers, Installed Bluetooth DAC For Audio, Added projection Puddle lights, Wind Deflectors, Fitted Apple TV to all 3 Screens, installed car WiFi, Fitted Custom vortex Exhaust
Old 11th May 2018, 10:04 PM
jza8's Avatar
jza8 jza8 is offline
Run one end from radio to tv tuner and then back to radio tuner again to form a loop, i don't think it matters which way it's all just a big loop.
2010 Audi A8 4.2 TDI
Old 12th May 2018, 06:22 AM
Ok thanks, how does one remove them from the clips? Just yank it or is there a method?
Jobs done so far;
Old 12th May 2018, 06:05 PM
jza8's Avatar
I fiddled with them a while ago, can't remember now, but pretty sure you don't yank them out, there is some sort of blue clip that you have to pull out iirc
Old 13th May 2018, 12:10 PM
Thumbs up
Awesome, thank you
Jobs done so far;
Old 13th May 2018, 03:54 PM
Bit late on this but the important thing is that:-
No question is stupid.
If you do not know the answer then ask.
Someone here will answer
It becomes stupid when you do not ask and the car dies.
Old 13th May 2018, 04:05 PM
It was only a stupid question because I thought I already knew the answer, I just wanted my hand held
Jobs done so far;
Old 13th May 2018, 04:21 PM
I like your honesty, Chip.
But that proves my point.
It's only stupid when you know the answer for deffo!!!
