Upgrade early FL 5 speed auto to S mode.
As you will know early FL 5 speed autos did not have the sport setting on the 5 speed. There is quite a bit about re-coding PF and FL boxes to change their shift patterns but little on converting a FL 5 speed with PRND432 to PRNDS. After a major refit of the Murple thanks to MJ with lots of work done we started talking about this and as she had a TCU from a late model FL S8, we thought we would swap mine out but keep the current shifter to see if it would work. It does. But there are some oddities. After fitting the replacement TCU the DIS no longer displays the PRND432 or PRNDS! nothing there at all! We took it out for a run with VCDS attached and the S mode works just as it shoud. In D the car changes up and down as one would expect. In 'TIP' the display comes back on and 5,4,3,2,1, are all displayed and gear changes happen as they should. However, select 4 on the shifter and, BINGO, VCDS says its in sport mode, the reves change and the box is indeed in Sport mode. Nothing shows on the DIS though. Select 3 and it all goes horrible wrong! Faults come up, the DIS reports no gear shifts in 'TIP' and I had to stop, turn the engine of and a couple of code were thrown on VCDS to the effect that the F125 switch was reporting an implausible position. As actually it should as there is no shifter position below S (4) on a sport shifter. So; why is the DIS not showing P,R,N,D,S when in any of those positions? Thoughts anyone?
